91 R32 Gtr // Doors And Rear Window Rubbers Any Helpers ?
If your looking for new RHDjapan sell these. Use pinpoint search on their site.
It is very Difficult to get good second hand external weather strip surrounds for the doors. You could remove (piss easy, screws on inside under weather strip) and repair by taking back to metal and repaint with Plastidip or similar paint.
For the rear window a car glass replacement company could remove/replace with an aftermarket bead. Do recommend.
Make certain you have no rust happening and if you do take action !
I do happen to have spare new beads for the rear window if you want to stay OEM.
Not easy to install. It's not a DIY job and will need to be held in place by the sillastic the pro's use.
Edit. Just noticed your door glass marks. Maybe just from washing and water marks.
But to clean. Remove the outer weather strip sills on both doors and clean the little buffer pads to stop your glass from scratching up. (those 2 lines on the door glass)
These collect dust and little stones etc... Single screw inside the door, lift gently. When out wash and ruff them up a little with a toothbrush and then put back on.
The glass can be polished with metal cream, polish, toothpaste or other non abbrassives. It will reduce any visible scratches.
Edited by Sinista32
  • 5 weeks later...
Man thanks heaps for that.. Really appreciate everything uv said and il do that she's just sitting ATM need a service lol I have already brought the back rubbers but it's only the outer pieces and I wonder if I need the bottoms :/ payed 350 .. 175 ea as they come in 2pc. Still need to get the door ones .. Will check out the site u suggested... Thanks again man ... Are u in nz ??
Sent from my iPhone using SAU Community // NZ AUCKLAND
Hey guys,
I am trying to find the same parts at the moment. Have been searching all over RHDJapan's site and have come up empty handed.
If either of you happen to find them on their website, could you link them here so I can grab them too? In the mean time, I'll keep searching and will link to them if I find them.
Cheers.
Updated
Sorry post cleared :(
For both sides the Rubber and retainer is $800 posted
here are the links (again)
http://www.rhdjapan.com/nissan-oem-body-side-weatherstrip-bnr32.html
http://www.rhdjapan.com/nissan-oem-left-side-weather-strip-retainer-65f00.html
Cheers
Edited by Sinista32
  • Like 1
  • 4 weeks later...
  • 3 weeks later...
#3 Tut-tut...
I would never go out on loose gravel roads to do such a thing...
...unless the rubber mouldings were included on the PDS juxtaposed to windscreen replacement ;)
  • Like 1
  • 2 years later...
digging up an old thread. In regards to the first photo where the rubber has fallen away and you can see the metal .. is that part the weather strip retainer? I need to order new ones but I'm finding it hard to know which part it is exactly.. ( I have no yet received my car to take the part off and get a better look at it for reference)
is this the part
https://www.rhdjapan.com/nissan-oem-left-side-weather-strip-retainer-65f00.html
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
