Hey guys I have a r34 GTT with a power fc just the stage 1 mods, and suddenly the engine light started flashing at around 5500rpm and is if there is like a boost cut.
I instantly thought it was knock and grabbed the hand controller and it was only like 10.
So I thought it might have been the injectors maxing out for some weird reason but they are at 92%.
Air Meter at 5100, I swapped over the AFM with a spare that I have and it's still doing it.
Next step I disabled the Injector warning - Still flashed.
Disabled the AFM warning - still flashed.
Turned the o2 sensor function off - still flashed.
What the hell could it be I have no idea, please help, thanks.
It depends what the warning is set out. You can set it to go off at whatever you like
The map sensor is for the boost control kit but does work without it. If you bring boost up on the hand controller and its got lines instead of a figure then you don't have the map sensor. I dont think you do but had to ask. I'm not even sure if it flashes the engine light anyway.
  • 2 months later...
Hey guys well it started again arhhh.
Weird although I have noticed that it mainly does it in the rain???
At about 4000 rpm mainly in 2nd engine light flashes car feels like it just turned off and back on then I back off.
I once thought fark it lets see what happens and it hesitates for a few milliseconds then goes fine, I'll attach a photo of my peak hold off my power FC if that helps at all.
I'm thinking either clogged injectors or is my fuel pump getting weak? if you think it's the fuel pump how can I test that?
Thanks for any help in advance.
Your airflow is getting borderline out of range (high)
Your injectors are borderline of reaching maximum
Both may be within the warning set in the Power FC. Depends what the tuner has set them to
Doesn't explain the problem with the drive from the car, but will explain the warning light I'd say. The Tuner may have set them at those levels, without FC-Edit to look at the settings then
If it were me, I'd be getting a Z32 AFM and some bigger injectors, then trying to troubleshoot the problem, because looks like what you have now is not quite enough to do the job safely. It may be a problem with the AFM, and you may find that spending $200-$400 on a Z32 AFM might solve your problem anyway.
Without more information though its hard to say for sure. It may be worth talking to your tuner about it so he can see the car and experience the problem
Yeah true, what trips me out though is that the car has been tuned like this for the past 2 years and now all of a sudden this is happening, I've tried 2 different AFM and 2 different o2 sensors just incase and same thing is happening, running the same boost and all, well I'm sooning aiming for my stage 2 upgrade, hopefully get near 300rwkw just stuck on which turbo to get, and which injectors, are the r34 injectors side feed or top feed? thanks.
Lose the whole 'stage 1' upgrades, etc.
Tune's dont always stay 100% perfect, in fact most of the time they dont. Differing temperatures for example will make a difference. Colder winter then normal for one
As the engine wears it will probably make a difference as well
It would be better to log data on a laptop and see exactly what the car is doing when the problem occurs. Hence why it would be a good idea to go see your tuner, see what he thinks. Becuase chances are he has seen it before
What you can try do is disable the ECU from giving warnings if your AFM or injectors are at peak. What I would do next is have the control in the mode which lets you view the sensors and if the ECU triggers a warning have a passenger watch the screen closely to see if one of the triggers switches off. If the ECU is throwing an issue, it can be reported by the hand controller, whether it be a threshold limit or a component failure.
Ahh k so put it in the sensors mode correct? And watch for one of the little circles to either come on or off yeah? It's not the light that bothers me I just don't want to blow anything - don't have the time or money for that atm.
It just trips me out as to why it mainly happens when it's raining and why all of a sudden if you get where I'm coming from, and also that little jurk that I get when the engine light does flash and what causes that? I'm thinking maybe as a safety precaution it's like a Rev limiter.
the engine light in my r33 flickers at times when im pushing past the 7,000rpm mainly in 3rd n 4th. Knock doesnt register any higher or go up when the light flashes, no engine damage or failures have happened and i have more than enough fuel and headroom with my setup. I've sort of learnt to ignore it and focus on knock readings
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
