Heya all, i've not had my Gtst long, and i'll be testing it next week, and wanted to get some idea of the figures i'd *expect* to see, within reason.... Afaik, it's not been tuned/touched etc since JustJap originally did the mods in Jan 2003
I'm still very much learning about 'lines - any recommended mods to improve from this point?
It's a '96 S2 Gtst with the following mods:
Mines Ecu (used)
T04 (recon)
Nismo Fuel Reg
3" Cat Converter
What I can guess as 'normal' turbo ducting etc..
(Pics : http://212.42.1.197/Zeb/line/bonnet1.jpg - http://212.42.1.197/Zeb/line/bonnet2.jpg - http://212.42.1.197/Zeb/line/line.jpg )
Tia -
Zeb
https://www.sau.com.au/forums/topic/44455-expected-performance/
After a bit of digging, and some great help from JustJap, (actually remembered my line :-D )
It's a T3/T4 Hybrid, with enlarged/bored out sections (Front and back), to increase flow. (Steel rather than ceramic)
He wasn't sure of exactly what size, and i'm not pulling it out ;-)
Hope that helps
Its 99% likely that the Mines ECU is set up for japanese conditions IE 100+octane fuel and way colder conditions
So running 98 which is the best octane we have here, at high boost and high rpm will see some problems
My advise;
Before doing anything with/to the car, put it on a dyno and see if theres any problems
I have seen about 4 Mines ECU's and all were very rich and not particularly aggressive in their tune. No speed cut was good, raised rev limit was a waste of time, boost cut removed was good, otherwise not such a good thing. :thumbdwn:
ok... done the dyno, am feeling a little dissapointed, as was expecting more.....
Max 227.8 HP :-(
I'll scan the plots in tomorrow, and hopefully SydKid etc could decipher it for me ;-)
The good news is that the power curve is pretty linear, (excluding end drop off )
It does look like Sydkid was right one one side, about top end revs on the ECU lacking, but.. it was running a little lean according to them....
Will get the scans done tomorrow...
I could be missing something here, but it looks pretty good for a start... (if on the low side)
i got a 141rwkw (189HP) with stock series 2 including stock exhaust and boost. You should be getting up near 180-180 at least with aftermarket turbo and an ecu chip. what exhaust do you have? it just says 3" cat. what boost are u running the t04 at?
Here's the plots :
Plot & Torque Showing
Plot & Mixture ??
Can anyone help with translating these plots into something I can readily understand, so I can look to improve this?
Excuse me if I sound like a complete noob, I am  :Oops:
Typical Mines ECU, stable A/F ratios but simply too rich. They need to be between 12 and 12.5, not mid 11's. The ignition timing will be similar, solid but too retarded. Did you get a boost graph?
Thanks for the comeback SydKid, I'll pop in to them tomorrow and see if they did do one.
The two graphs were all they gave me.
If I was looking to up the overall power etc, would I be looking at changing the ECU & Retuning? or would it be a lot more involved?
(I'd love to get to the 350 *ish* HP, but i have no idea if that's a realistic goal with the current setup. )
If so, what sort of ECU would be idea? Something like a Wolf3d?
Tbh, I've got about 5-10K I could throw at the car if needed.
Power FC would be my choice and with a decent intercooler and fuel pump there is no reason why 225 rwkw (300 rwhp) would not be easily obtained. With larger injectors and an AFM upgrade (to Z32) 250-260 rwkw (350 rwhp) is there for the taking. There are pleny of threads on this sort of upgrade path, do a search, I am sure you will find all that you need to know. :cheers:
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
