Nissan Skyline R32 GTR 1992
Located Inner West Sydney
Contact: 0431296367
Price: $24500 ono
Please no time wasters
11 months rego
Making 372 KW @ the rears on pump with 18psi (have dyno sheet)
G4 link ECU
Forged engine with -5 twin turbo
Comes with plenty of receipts to prove all the below work has been done.
Also have plenty of pictures throughout the build stages.
Full chrome engine bay
Engine has no more then 4000-5000 kms since rebuild Chassis has ~ 108xxxkms
Very regretful sale but like most GTR’s it barely gets driven I am a very fussy owner and I have taken extremely good care and maintained very well keeping the servicing up to date and keeping it looking fresh Lots of money spent to get where it’s at today All the engine parts listed below were purchased brand new when fitted
Performance:
G4 Link ECU
Forged pistons and rods
Bored out to 86.5mm
Garret -5 twin turbo’s
Expreme twin plate clutch with lightened flywheel
ACL racing bearings
Balanced crank
Nitto oil pump
Tomei head gasket
Tomei baffles
8L sump
ARP head stud, main studs and flywheel studs
Tomei type B poncams
Tomei valve spring retainers
New valves
HKS cam timing pulleys
Bosch timing belt
Clear Cam cover
HKS fuel raise with 100cc denso injectors
Sard fuel regulator
3L surge tank with bosch 044 fuel pump
Braised fuel lines
Spitfire coilpacks
Tomei dump pipes
3 exhaust dump pipe back with 100 cell cat and Varex cannon
100MM front mount
Hks oil cooler with Greddy oil relocater
Aluminium catch can
Aluminium radiator
K&N pods filters apexi super suction piping covered in box
HKS SSQV BOV’s
Suspension/exterior:
Bilstien adjustable coilovers with damper adjust
Camber arms and castar rods
Whiteline sway bar
Slotted rotors
Genuine N1 front bumper and
N1 rear spoiler copy and rear pods which are yet to be fitted but already painted)
17” Buddyclub P1’s
Interior:
Greddy profec B boost gauge
Greddy Turbo time
Greddy Boost gauge and Exhaust Temp gauge
Nismo gear knob
Genuine floor mats
Carbon fibber centre dash with chrome rings around the cluster and gauges
Pioneer Bluetooth head unit usb aux etc..
Pioneer speakers
Edited by thegame-01
sent you a message on Facebook.
can you send me additional photos of the interior and exterior in normal lighting?
any more detail on the "forged engine" e.g. rods, pistons, oil gallery modifications etc?
also did advan do all the work for you?
  • 1 month later...
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
