Hello I did a search for cam gears on this forum and cant really find anything.
Are adjustable cam gears worth it on a rb20? Will it help with torque?
I have a stock rb20 with stock turbo. I have a full turbo back exhaust with sports cat, and a pod and return to stock piping fmic.
I am putting in a boost controller soon and possibily a rb25 turbo.
Edited by yoshiii335
Tiny benefit with everything stock, and therefore not worth the cost or effort.
Here's a suggestion for the turbo. Buy an RB20 turbo from someone in Australia (like on these forums, or Gumtree, or eBay, or whatever). It doesn't matter if it's broken, because you would get the seller to send it to Hypergear in Melbourne. He would highflow it for you and send it to you in Japan. Much better idea than running a ceramic turbo again (the RB25 turbo).
How much does it cost to highflow it?
So adustable cam gears work when the boost is up?
Yes. They might be worth it.
Depending on what you consider worth it
You would have to spend time in the dyno to see what the engine wants.
What do you mean what the engine wants?
Too many questions in too many threads.
Why do you not use tools like google to look up Hypergear and find out what his highflow service costs?
Adjustable cam gears on stock cams on an unopened motor will definitely give you SOME result. As Ben said. But the problem is that the result will likely be too small to justify the cost and effort when you could use the money and time more productively on other mods. What Ben means by "what the engine wants" is exactly that. You can really only find out where to set adjustable cam gears to get the result you're after (whether that's max top end power or a little more bite at the bottom at the expense of top end power) by adjusting them while at the dyno and doing runs to see what results you get. The result you get depends on what your engine is happy with, and that depends on what turbo you're running, how much boost that turbo might be making, etc.
But it's not simply a question of "do cam gears give you more when you have the boost wound up?" Really, the strict answer to that is yes, because when the boost is wound up everything gets bigger, including the size of changes from non-boost related mods. But, no, cam gears do not become more important as boost rises.
Thanks I understand now.
To high flow it will cost you $850 including braided oil line. I do have a couple of different combinations, smaller profiles is more relatively more responsive then bigger combinations.
Power wise smallest profile can support 210rwkws with full boost around 3800RPMs, while the larger profiles can handle 240rwkws with full boost around 4500RPMs.
The adjustable cam gears helps a tinny bit of mid range. But not a very tangible amount using stock cam shafts.
I checked out your site, nice stuff. So stock full boost on the rb20 turbo is at 5600 rpm, so having a turbo come on full boost by 4500 is good, correct? Do you have an option to get me to 400hp with similar responses for street?
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
