wouldnt surprise me though lol
its got 145xxx on the clock now
On the export sheet its says its done like 30000 k's in 4 years or something like that, if have to have another look later today. Its in pretty good condition so you would think the km's are genuine otherwise it would have wear and tear if it was wound back.
