so my R32 GTR randomly decided it doesnt want to start anymore, fuel pump no longer runs with ignition on
fuel pump had been re-wired for direct battery voltage and FPCM had been earthed so pump was alway on full voltage
checked the relay clicks (near ecu), directly jumping the fuel pump is fine, so issue appears to be signal to relay, swapped over relay in the boot and horn relay to another but no dice
checked engine bay and cabin fuses - all good
re-soldered a dry looking solder on pin connector of FPCM and re-did earth - no change
checked earth and power in boot, next to check the ecu (pfc handcontroller does not show F/P running till cranking - whereas with FPCM earthed, used to run continously on ign)
what's the go with pin 18 on the ECU, is it for ground or power signal to relay?
https://www.sau.com.au/forums/topic/444698-faulty-fpcm-no-signal-to-fp/
IGN power to the top of the coil on the realy, then earthed through Pin 18 on the ECU
So if you don't have power on the relay coil siide with ignition on, then you have a power problem, If you have power then quite possibly an ECU issue
Depending on how you have done the Direct feed to the pump, it may still be utilizing the the FPCM, in which case you can get rid of it completely but just running the Battery power to one side and the other straight to ground. There is no need to keep the FPCM
Should be able to work it out with that diagram anyway
Edited by 89CAL
Thanks for the diagram, appears to be a power short somewhere, f/p fuse keeps blowing on ignition and no 12v to relay in boot
have disconnected ecu and front passenger side relays and still blowing, going to check wiring on cabin fuse block
So 15amp fuse (Fuse #41)? It's not something silly like someone has put the wrong fuse in there?
That fuse is purely for the fuel pump relay by the look of it. Can you confirm that the fuel pump works?
Also have you bypassed the FPCM so it just goes straight in the pump and then to ground?
Really it can only be the relay or the fuel pump once you ground the other side of the pump (ignoring the FPCM)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
