My RB20 is pretty well stock apart from a little bit of boost and a 3 inch turbo back exhaust and it surprised me what I could keep up with.
I'll push Pinky harder next time... :P
I think that the R32s being lighter in comparison to R33's is rather noticeable on track.....
Add a few light mods and you guys were fanging around the track IMO
pretty much,definitely helps out when up against insanely powerful cars,luckily mines pretty well set up in the suspension so can out corner alot of other cars,but my tyres had lost most of there grip near the end of the 53 minute happy laps.Could feel them crying underneath me,but my brakes handled the torture really well,but i did notice a light vibration under hard braking near the end,may need to look at the rotors and pads soon.
They're only about 75kg lighter...
well add your 30kg of doof doof Mike and you have a 105kg disadvantage right there
When we had our last suspension tech night we had our cars weighed, mine was about 75kg heavier than Pete's old 32 GTST. That was with mine totally full of fuel and all my audio gear in it ;)
LOL "The sprint tracks way to f**king small for this, way to f**king small" I think everyone echoed those thoughts.
Yeah, glad they set up the clubman. The national would have been even better.
That's weird Mike.
The kerb weight of an R32 GTST is 1,280kg and R33 GTST is 1,390kg
You been shifty and stripped shit outa the SS
On my rego it says mine is 1340kg and also has stereo stuff in it and a full size spare
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
