First off, get rid of Hicas. Then buy everything! Springs, shocks/coilovers, castor rods, camber arms, replace bushes, alloy rear cradle mounts the list goes on.
Stick your head in here and have a read
http://www.skylinesaustralia.com/forums/forum/59-suspension-braking-and-tyres/
That's more effort than you put into my lists... Why is it that when I ask you wave your hand and respond with everything :P
Suspension is a trade off however....
alloy subframe bushes etc probably are to harsh for regular steer bushes I think
I have alloy subframe bushes in mine and they aren't harsh at all.
Because yours needs everything as well? It's the same in each car depending what it has done already, if stock then everything. Where to start is the question.
So I was thinking right that you have alloy bushes, I didn't say anything incase you didn't have them and I was thinking of SKY...
Well, that response was more serious than I was expecting... Something along the lines of because needs less pink 33 is more your usual answer...
Screw budget man. Ill buy stuff eventurely .. List it up :)
What sort of handling are you after? This will determine how much stuff you replace.
I have finished with my suspension now and I have:
Bigger wheels and tyres
Coilovers
Strut braces
Sway bars with HD links
Front and rear camber arms
Front and rear castor rods
Polyurethane diff bushes
Solid (not alloy tho) subframe mounts
HICAS eliminator kit
Total replacement of remaining factory bushes with polyurethane including steering rack bushes
Front and rear LCA ball joints
Steering rack tie rod ends
Rear wheel bearings
The car now handles amazing ans is still easily drivable on the street, it makes a few more noises and has some diff whine but I don't mind that.
all good. Ima gonna fabricate some brake ducts and also get the rotors the right way round lol
thats a good start but the national isnt any worse on brakes cause youve got the long back straight to cool them down,also depends on how hard on your brakes you are,normal braking and engine braking will do the job.ie gear changes.
Notional ruins brakes, that long back straight lets you build up some serious speed and then it ends in a very tight corner.
then again it has been along time since we have done it,but ive never had any brake problems when i have done it,maybe not going fast enough,lol.
When I did it during sprint practice my breaks were cooked and starting to fade after 3 laps. Braking at 100m doesn't help either...
brake upgrades are always on the shopping list,was just checking out discs and prices not 5 minutes ago,will go on the bucket list,its getting farking long now.Will fix leaking power steering first and go from there.
is that back straight longer than the front straight?
My long happy laps vid, including random commentary by me. Contains quite a few F bombs...
loved the video, loved the commentary.. wondered if anyone else thought the same as me about the slow cars in the corners.. but then I thought that people were probably wondering why I was going so slow on the straights! I saw you pass me like I was standing still lol...
I had a minor freak out the first time the camera "crashed" lol.. what sort of camera were you using? gopro style or a dashcam?
Yep, plus the speeds are different.
Naturally these are sprint day speeds NOT happy laps speeds.
I normally enter the main straight at 100kmh and enter turn 1 at 140, the exit of turn 2/start of the back straight is also at 140-145kmh, the entry into turn 3 is about 80kmh and during a race you're breaking as late as possible. As you can see you have the potential to be going a lot faster at the end of the back straight than the front and the corner at the back is much tighter and slower.
Genuine GoPro with a 3rd party suction mount. Video was fairly crap quality because I dropped it down in post so it wasn't 7gb of uploading.
    • Welcome to the site. Any more pics? That colour is gorgeous.
    • I didn't even know that existed!!! Amazing, good work Andy at Haltech! A bit off topic here, but I actually met Andy at a Aus Lancer car meet at the old Shell Space Station in Ryde back in 2003 or so. He brought out this aluminium case and showed everyone this basic circuit and said he was making an ECU that was capable of using closed loop to self tune. Most of the people there dismissed his idea.
    • I actually was using 4D tables with my old AEM WMI system. I'm now using "Water Injection Advanced" under engine functions to control my WMI. The timing and fuel corrections are easier to use as they have WMI in mind. Example, my fuel correction is based on my WMI solenoid duty cycle, they also included built in timers to delay corrections before and after spraying, timers to ramp up pulse width, etc.
    • Just a thought, how come you didn't use a 4D table? So you essentially run 2x fuel and 2x ignition tables, and the table/map switch is handled when there's enough WMI pressure detected. This is mine, but using the flex sensor as the 4th dimension, note the slider at the bottom. Between 0 to 70%, the timing is blended/interpolated , once it goes past 70% ethanol full send
    • Hi guys, after dreaming of owning a JDM legend for 20 years, I got the chance to buy a 1995 R33 GTR.  I live in a small country called the Solomon Islands which is in the pacific. There is no performance car scene here, however 90% of vehicles here are 2nd hand Japanese imports so there is a handful of JDM sports cars here, tucked away.  3 Evo VI’s, 1 180sx turbo, 2 GTO’s, 1 R32 GTR and 2 R33 GTR’s.    Only 1 Evo and a 33 (mine) are active. I’m hoping to set up a club to get these cars back in the road.    I’d known of my GTR for 9 years and always dreamed of owning it. At the start of this year I found it sitting outside a workshop waiting for a respray. It was in pretty bad shape, although running and driving perfectly apart from a big exhaust leak and worn out bushings. My brother in law who is a huge GTR guy came over for a holiday and I took him to see it, he got into my ear and I bought the car 2 weeks later as is.   I’ve had a pretty bad problem with alcohol and weed since 2020 and I really wanted to quit. So I used this as my motivation. I quit everything cold turkey and have been investing all my spare time into restoring this car. It’s honestly been the best experience and has been such a positive impact on my life.  There is no market for these cars here, no parts and no mechanics that can work on them, so if you wanted to sell one it would be pretty impossible unless you found the right buyer. After a bit of negotiating with the previous owner (a good friend) I got the car for $15,000 AUD ($85,000 SBD) which is insane.  I’ve almost finished doing a refresh on the engine, new turbos, spark plugs and split fire coil packs. Also new gaskets and seals, This car had no leaks to begin with, but it’s due now being 30 years old. . Next I’ll be working on the suspension, all new bushings, ball joints, king pins and new coil overs.  Then it will be body work, it has really bad rust in the boot floor, I have purchased a rear beaver cut from my bro which will replace the rusted out one. The car is originally KL0, but was burnt orange when it landed here, then it was resprayed toxic green and then Bayside Blue. I’m probably going to get it redone in Bayside Blue.  I’m super grateful to be able to enjoy this car and couldn’t have done it without my bro Chris from OG-JDM. Looking forward to the future with this car and hoping to get it on the runway at the airport here 😂  cheers fellas
