Buy 2 Get 1 Free: Samsung Galaxy S5 $400Usd/iphone 5S 64Gb Gold $400Usd (Ramadan Offer)
Welcome back! There is a v series forum, a little quiet at times but every new active member helps
But, per MBS206's question, what happens when it doesn't start. When you turn the key to IGN, do the dash lights come on (then go off after a couple of seconds) - likely alarm or other electrical issue When you turn the key to STRT do you head a clear click (the starter solenoid trying) without the engine turning (likely starter motor)
I had 3 counts over the last couple of weeks once where i got stranded at a jdm paint yard booking in some work. 2nd time was moving the car into the drive way for the inspection and the 3rd was during the inspection for the co2 leak test. Fix: 1st, car off for a hour and half disconnected battery 10mins 4th try car started 2nd, 5th try started 3rd, countless time starting disconnected battery dude was under the hood listening to the starting sequence fuel pump ect.
This. As for your options - I suggest remote mounting the Nissan sensor further away on a length of steel tube. That tube to have a loop in it to handle vibration, etc etc. You will need to either put a tee and a bleed fitting near the sensor, or crack the fitting at the sensor to bleed it full of oil when you first set it up, otherwise you won't get the line filled. But this is a small problem. Just needs enough access to get it done.
The time is always correct. Only the date is wrong. It currently thinks it is January 19. Tomorrow it will say it is January 20. The date and time are ( should be ! ) retrieved from the GPS navigation system.
