Bride \ Recaro Express Group Buy #2 "replica" Seats Carbon , Kevlar ,frp ,glitter
Hi guys due to a big amount of interest's i will be doing another group buy.
This one will be different as i won't be custom ordering the seat's to order instead i will be order the seat's from the factory that are in stock or are already in production. ( This group buy will be much quicker )
Start Date 20/7/14
End 20/9/14
I have given it 2 months but if we reach the 10 people limit i will put it thru ASAP.
Bride Replica Chairs , Remember these are not genuine but are replicated in high quality for a much better price.
We need about 10-15 People in this to proceed otherwise will be canceled !
Company called : Wujiang Jianwu same company doing my CF Group Buy they seem to make the higher end quality in China.
ALL PRICES INCLUDE SHIPPING TO SYDNEY GENERALLY ABOUT $550 FOR A PAIR OF SEATS.
The more we order the more i am able to ask for discounts without sacrificing quality.
There is a low quality low priced option and a higher quality more expensive option i have chosen with the higher quality as i do not want cheap replicated seats.
Standard Size Seat's will fit size 28-34
XL size would be needed for 34-38 however it seem's like there is non in stock atm.
Current seat's ready from factory
BRIDE STRADIA II - GLITTER $750
BRIDE STRADIA II - FRP $680
BRIDE STRADIA II - Carbon $970.00
BRIDE STRADIA II - Kelvar $970.00
Bride StradiaII Sport Style- Glitter $750.00
Bride StradiaII Sport Style - Frp $700.00
Bride StradiaII Sport Style - Carbon $950.00
Bride StradiaII Sport Style- Kevlar $950.00
Bride Stadia II Maizora - $750
Bride Low Max Gias 2-Glitter $750.00
Bride Low Max Gias 2 - Frp $680.00
Bride Low Max Gias 2-Carbon $970
Bride Low Max Gias 2-Kevlar $970
Bride low Max Gias 2 Sport Style- Glitter $750.00
Bride low Max Gias 2 Sport Style- Frp $750.00
Bride low Max Gias 2 Sport Style- Carbon $970.00
Bride low Max Gias 2 Sport Style - Kelvar $970.00
BRIDE STRADIA SPORT - Carbon Black Alcantara $1050
BRIDE STRADIA SPORT - Kelvar Black Alcantara $1050
BRIDE VIOS III - FRP Black Alcantara $650
BRIDE VIOS III - FRP XL SIZE $700
All these prices are a rough estimate as the final depends on our $ conversion
Prices is for a set of 2 seat's
Universal seat rails are included.
  • Like 1
Josh : They all come with universal seat rails
JezR31 : all FRP come with black back the 4th picture one is a Bride Venus Or Maizora.
NISR32.5: Not too sure yet as the factory is on back order due to high demand
Stag98 : Size 34 should fit no problem for standard size
Group Buy List.
Longz : Bride Stradia Alcantara , Bride Low Max Gias Alcantara
smg084: Stradia 2 Sport Style-frp
lokiR33 : BRIDE STRADIA II - FRP Black
Hi
Are you able to put me in touch with anyone in QLD to who got a pair of the Stradia or Gias in the last group buy?
I would really like to check them out first. (no offence intended)
Jezr: Bride Stadia II Maizora Graduation Fabric
Stretch gsk - buyers from qld ADUBZ
Josh080 : no singles at the moment it seems.
Nisr32.5: No worries will let you know if anything changes.
green180sx: It is the Bride Maizora or Venus.
Current List :
BLK-51N : Bride low max gias 2 carbon back in black gradation standard size
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
