Bride \ Recaro Express Group Buy #2 "replica" Seats Carbon , Kevlar ,frp ,glitter
Hi guys due to a big amount of interest's i will be doing another group buy.
This one will be different as i won't be custom ordering the seat's to order instead i will be order the seat's from the factory that are in stock or are already in production. ( This group buy will be much quicker )
Start Date 20/7/14
End 20/9/14
I have given it 2 months but if we reach the 10 people limit i will put it thru ASAP.
Bride Replica Chairs , Remember these are not genuine but are replicated in high quality for a much better price.
We need about 10-15 People in this to proceed otherwise will be canceled !
Company called : Wujiang Jianwu same company doing my CF Group Buy they seem to make the higher end quality in China.
ALL PRICES INCLUDE SHIPPING TO SYDNEY GENERALLY ABOUT $550 FOR A PAIR OF SEATS.
The more we order the more i am able to ask for discounts without sacrificing quality.
There is a low quality low priced option and a higher quality more expensive option i have chosen with the higher quality as i do not want cheap replicated seats.
Standard Size Seat's will fit size 28-34
XL size would be needed for 34-38 however it seem's like there is non in stock atm.
Current seat's ready from factory
BRIDE STRADIA II - GLITTER $750
BRIDE STRADIA II - FRP $680
BRIDE STRADIA II - Carbon $970.00
BRIDE STRADIA II - Kelvar $970.00
Bride StradiaII Sport Style- Glitter $750.00
Bride StradiaII Sport Style - Frp $700.00
Bride StradiaII Sport Style - Carbon $950.00
Bride StradiaII Sport Style- Kevlar $950.00
Bride Stadia II Maizora - $750
Bride Low Max Gias 2-Glitter $750.00
Bride Low Max Gias 2 - Frp $680.00
Bride Low Max Gias 2-Carbon $970
Bride Low Max Gias 2-Kevlar $970
Bride low Max Gias 2 Sport Style- Glitter $750.00
Bride low Max Gias 2 Sport Style- Frp $750.00
Bride low Max Gias 2 Sport Style- Carbon $970.00
Bride low Max Gias 2 Sport Style - Kelvar $970.00
BRIDE STRADIA SPORT - Carbon Black Alcantara $1050
BRIDE STRADIA SPORT - Kelvar Black Alcantara $1050
BRIDE VIOS III - FRP Black Alcantara $650
BRIDE VIOS III - FRP XL SIZE $700
All these prices are a rough estimate as the final depends on our $ conversion
Prices is for a set of 2 seat's
Universal seat rails are included.
  • Like 1
Josh : They all come with universal seat rails
JezR31 : all FRP come with black back the 4th picture one is a Bride Venus Or Maizora.
NISR32.5: Not too sure yet as the factory is on back order due to high demand
Stag98 : Size 34 should fit no problem for standard size
Group Buy List.
Longz : Bride Stradia Alcantara , Bride Low Max Gias Alcantara
smg084: Stradia 2 Sport Style-frp
lokiR33 : BRIDE STRADIA II - FRP Black
Hi
Are you able to put me in touch with anyone in QLD to who got a pair of the Stradia or Gias in the last group buy?
I would really like to check them out first. (no offence intended)
Jezr: Bride Stadia II Maizora Graduation Fabric
Stretch gsk - buyers from qld ADUBZ
Josh080 : no singles at the moment it seems.
Nisr32.5: No worries will let you know if anything changes.
green180sx: It is the Bride Maizora or Venus.
Current List :
BLK-51N : Bride low max gias 2 carbon back in black gradation standard size
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
