Didn't you notice when you put the cam cover back on?
Unfortunately I didn't put the cover on, I gave it to the tuner to put back on once they finished adjusting the cams (basically I installed the cams, then left the cover off to drive to the tuner to get them adjusted on a dyno). I would have thought they would have noticed and repaired/told me about it if it was damaged!
Makes me wonder if they even adjusted the cam.....
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
