I just read that gap 1.1mm is fine on rb25de neo and the bcpr7es plugs I bought had an abbreviation of -11 at the end, so I'm guessing they are already gapped to 1.1. I also read that the recommended plugs are PFR5G. It it worth just testing the ones I got or should I swap em for the recommended plugs?
https://www.sau.com.au/forums/topic/446133-ngk-bcpr7es/#findComment-7353176
Correct that the -11 means a 1.1 gap.
Depends what you consider worth it.
They will more than likely be ok, but being colder and in an na the chances are they will foul easily .
I use them, but my car is running 20 psi .
https://www.sau.com.au/forums/topic/446133-ngk-bcpr7es/#findComment-7353193
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
