hey guys,
Before you ask i have searched for this heaps and cant find an answer,
I have a R32 gtr with a vipec ecu, How do i go about installing the ID1300 i have bought and they are high impedance and stock gtr injectors are low... as far as im aware.
I have heard about connecting all the wires and removing the resistor but i cant find the resistor and wont this cause all the injectors to fire at the same time wasting alot of fuel?
Cheers
Ethan
Well seeing as you will have to get it tuned why not ask your tuner?
And no it won't make all injectors fire at once. That would be a silly thing to do that no one would do.
yeah is sounded silly,
yeah ill ask my tuner, thought there might be an easy fix i just didnt know
Getting rid of the resistor pack is easy. But to be sure ask your tuner and he will have you sorted in a minute.
I think I see what you're asking.
The system runs a 12V positive feed to the resistor bank and from that bank, 6-individual feeds head off, one to each injector.
The injectors are fired by the ecu grounding each injector.
Joining all 6-feeds to that 12V positive and removing the resistor bank, you're setting it up the same as a high impedance Rb20.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
