Howdy peeps,
Would like peoples opinions on intercoolers in 2 areas.
1) I can get hold of a GTR 2nd cooler and installed for about $950.
Should i go for that or get a kit thru nengun like the V-SPL brand new for $1300 and install myself (maybe)
2) If the GTR cooler is bought and installed, is running the piping back under the cooler back to the origin piping the best option or better going thru the "hole in the wall" method. The distance looks almost the same.
Thanks guys....
https://www.sau.com.au/forums/topic/44783-gtr-2nd-intercoolers/
If you decide to run with GTR cooler, you'll be much better off to run the return up through the gaurd to the plenum. A nightmare to plumb it nicely the other way 'cause the GTR cooler is higher than the aftermarket ones that have the "under" return.
Remember that when you fit a GTR cooler, the top edge will be virtually hard up against the bonnet latch, and the bottom edge will be pretty close to level with the bottom of a standard front bar. Therefore, if you want the return pipe to hang lower than your front bar go for it. Might not last long though!
I would suggest you bring the return pipe up through the inner gaurd and over to the plenum above the radiator, that is of coarse if your not prepared to re-locate your throttle body to the front of the engine.
The taper that the gtr cooler end tanks have are not straight like some.I say if your going to run the pipe back under to the origional posi buy a hybrid or anything that will meet your requirements for performance and budget.
This is what i am doing and allthough i have most of the pipeing allready its going to cost me next to nothing for some brackets and silicon hose on top of the price of the cooler.
do a search on places like www.cappa.com.au for mandrel bends just to give you an idea of prices + sizes for them and i can pretty much guarantee you that you could do it all yourself for a cheaper price.They are all highly polished as well.Theres probably place's cheaper than cappa and if you dont want the high polished look theyre even cheaper as i understand it. :headspin: :headspin: :headspin: :headspin: :headspin:
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
