Hey all,
Not sure if anyone here recalls but some years ago, my car was written off. Long story short, the matter went to court, I won my case. 3 years later the other party still has not made any effort to make payments. I don't want to go to a solicitor again since they charge an arm and a leg. I just need advice. Where should I go with this? There is no expiry date/response date on the judgement. All it says is the defendant is to pay plantiff x amount of money and after 28 days interest will be charged at 8.5%
If anyone has any suggestions that would be great. This stressed me out for far too long and I just want it done and dusted.
https://www.sau.com.au/forums/topic/448099-need-some-legal-advice/
Hey all,
take the judgement down to the courthouse/sheriffs office and ask them if their is a date it has to be paid by, i find it strange that there isnt one
It is an two individuals. They're still around. I made some phone calls. I need to fill out some forms for the Sheriff but they ask for details about the other party(address, number etc) which I cannot provide. Tedious task.
I can't remember who was telling me but there was this agency my mate went too where they would only be paid after they completed the debt collection, it was about 10% more but still you pay them once they've sorted through the mess. it's a really annoying situation but I'd advise just talking with the police etc, as it can be a pretty serious crime if you don't pay a debt after a long situated time.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
