Yes, 350z parts are fine to use, I don't know about the fwd maxima.
Now, the only way to fix the plug tube leak is to buy a whole plastic cam cover, which is a pretty expensive fix. If you not talking about a lot of oil, and it isn't coming from the outside of the valve cover (that seal is replaceable), then it's best just to leave it alone. It doesn't effect any performance, as it's an insulator.
https://www.sau.com.au/forums/topic/448212-m35-gaskets-35l/#findComment-7381070
Thanks guys - appreciate the guidance!
And make sure you get parts reference from a 2003 350z
They got some engine changes in 2006 I seem to recall.
Just so I am clear on this - are you saying that the 2003 350z engine is the best match as the local 2006 350z engine changes mean it differs from the 2006 Stagea set up?
Thanks again.
https://www.sau.com.au/forums/topic/448212-m35-gaskets-35l/#findComment-7381082
All 3.5 stageas got the same motor as a 2003 350z
2006 350z received the "revup" motor, that would be 95% similar, but had some changes.
Models after that got the vq35hr which is significantly different.
https://www.sau.com.au/forums/topic/448212-m35-gaskets-35l/#findComment-7381092
You could use your vin to check parts, that way you know they are correct. EPCdata then Amayama. ;)
As Alex said, the plug tube gaskets are not replaceable, you will need the entire rocker cover which will set you back $250 odd. As the oil only weeps in, and the oil is an insulator, you have no problems if you ignore it.
https://www.sau.com.au/forums/topic/448212-m35-gaskets-35l/#findComment-7381097
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
