R34 NIStune ECU and Z32 AFM
ECU was sent to Matt @ NISTune to have the board installed, was then returned and went straight into my car. Tuned by Trent @ Chequered tuning in Melbourne and made 312kw @ 20psi with Z32 AFM. I am now in need of a car with MAP sensor functionality so i have outgrown this. It is a very very capable ECU and great if you want to keep your street car mods very discreet, remove the NIStune sticker and the police will never know its modified :)
Z32 was purchased BRAND NEW and only used for maybe 4000km's if lucky. Same reason for upgrade.
NISTune ECU $500
Z32 AFM $230
Happy to post at buyers expense, located Newcastle NSW. Contact Josh 0437 one 33701
https://www.sau.com.au/forums/topic/448299-r34-nistune-ecu-and-z32-afm/
  • 3 weeks later...
