Any Of You Guys Want To Make Some Money?
At 19/09/2014 Apple will release their new Iphone 6 and Iphone 6+
It easy you just need to go to Apple Store (Chemside or Carindale) to buy as much as you can and I will give you $50 on top of the each iphone you supply to me.
For example: A couple of 2 and 1 kid you can buy 6 iphone and you make $300 in one trip to there. And if you line up again and get 6 more and you make $600 in one day.
You supply me more you make more, all settle in CASH. I don't care what you pay to buy cash or card, I only have CASH to pay you back.
This is the list of models I need (The color i perfer is : 1.GOLD, 2.WHITE, 3.GERY)
Iphone 6 plus
1. 16GB
2. 128GB
3. 64GB
Iphone 6
1. 16GB
2. 128GB
3. 64GB
If you interest please PM me with your name and contact then I will give you a bell to tell you what to do. Thanks vey much
Edited by shkcho
Trade the bell for smokes, from memory he can get cheap ones. This new tax is a killer
http://www.sau.com.au/forums/topic/439762-cigarette-for-sale/#entry7210885
Edited by MagicMikeZ32
Yes thats fine you buy those iphone from Apple store with a invoice and you sell them to me and get the cash, its a simple trading its your choose to let them know or not. That's not my problem I only need the phone and the invoice
Hey guys, if you guys want to make TAX FREE money just PM me with your contact number. I will call you on next Wedensday (17/09/2014)
There is no such day as Wedensday... Unless you mean Wednesday?
Also, you want people to line up numerous times? Why not save yourself some cash and do it yourself?
Must be able to affort many things we cannot. Sadly I do have dreams of selling durrys from the boot of my Ferrari F360 and operate a in-home anal bleaching service from my Mercedes c63
Haha. I remember that thread. Gold!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
