It's a n/a rb30 series 2 block and it's an RB30DET now. I bought a half done motor and pretty much have pulled everything apart over months and rebuilding it. I figured I'd bugger off the bulky heat transfer and add an oil cooler and remote mount. This was the first time I removed it.
Someone added the heat transfer block then. I'm pretty sure the thing they destroyed in the process(your photo) is the oil filter bypass valve (used when the filter is blocked to bypass it)
I would pay carefully attention and see if you need to block it up or else you might be bypassing the oil filter now.
Fairly certain my old 30 blocks had this filter by-pass valve.
It's a steel ball and spring style which when operating, simply by-passes the filter.
Yours would be doing this all the time.
I think I can see the remains of the spring in one of the photos, also not good.
Definitely needs attention.
If you're doing a rebuild, you need to remove all gallery plugs, strip/clean/flush anything to do with oil supply.
Don't trust any work done by a previous owner, as this clearly shows.
It might not be all doom and gloom though. I think if you look into it the heat exchanger has the bypass valve in it, which is perhaps why the original owner hacked it out of the block.
You "might" be able to just put the heat exchanger back on, but the piece of spring sitting there is concerning and will need to be dealt with. It's also an indication of the previous owners workmanship which is a shame.
The previous owner was a bell end. I bought the rb 25/30 all excited then I got home after the 2 hour drive and found rust and leaves all through it. I have removed the head and rebuilt based on these shonky findings.
I think I might try tapping a thread through the shit and screwing a bolt in there. I won't run the relief valve.
Edited by negativecamber
Fair enough. There's no real need to actually run the valve..its only there incase the filter gets so blocked it can't flow oil, which I'm sure you would never let it get that bad before servicing the car.
The only thing is to make sure you get rid of all of the swarf caused by tapping it.
I'll vacuum the hell out of it and I currently have the sump off so I'll make sure no dwarf gets anywhere. I had a similar experience with installing a rear head drain the other week.
It's a track only drift car so it will have regular fluid/filter changes.
Thanks for your help guys.
I've been changing oil filters for at least 50 years and I've never come across a spin-on that doesn't incorporate a by-pass valve.
Owners should understand the by-pass will open when the filter medium becomes blocked and also on cold start when oil is at its max viscosity.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
