Plenty of people run without VCT so is it really that detrimental to the cams? Keeping in mind I have a Neo head which is different to R33.
And I have absolutely zero motorvation (pun intended) to do anything on the piece of shite at the moment.
I know that and I completely understand why, yes VCT is very worthwhile. Only a few months ago I would have said anyone is crazy not keeping VCT. But in my situation I am very time restricted and have zero drive to do anything on the car at the moment.
  • 2 years later...
sorry to revive the thread i have the exact same leak happening on my car. I am about to pull the head off and redo it. The engine is a 25/30 too and im not sure if the previous engine builder made a feed to the cam journal. So I thought id check that while the head was off.
what was the root cause to the oil leak?
It was coming from where my 'fabricator' had tried to weld a fitting to the head for the external VCT. That head turned out to be junk and I had to get a new Neo head. The second head was then tapped and died and a fitting screwed in instead.
Where exactly is yours leaking from? And how is your external VCT feed setup
  • Like 1
I too have a similar situation but mine appears to be from the rear passenger side.  I have noticed a bit of oil around the front cover but it doesn't drip from there at all. Haven't looked into it much as i have walked away from it and other things for a bit. I re torqued my head just to make sure and used a rb30 mls cometic 1.3mm head gasket. Head was fully refurbed by a head shop and block was also machined sqr to deck  when built to get 100% 0 deck height and blue print it.
The issue is that I bought the car with an RB25/30 built engine.The sneaky bugger must have washed it off or something before I inspected the vehicle.
I've attached a picture below of what it looks like. I'm hoping it's the shitty blank off that's been used. If that's the case it will be an easy fix.
On 3/11/2017 at 4:30 PM, Borci88 said:
Are you sure it's not just a leaking cam seal Bryce?
I'm hoping its something minor like that. It would suck regardless having to replace cam seals. Ill start by replacing the blank off to see if that solves the issue.
  • 2 months later...
Can someone tell me the right 3-Bond to use.
I'm going to be attempting this tomorrow. Would rather not undo the cams. I know it's dangerous and could snap the cams. But has anyone taken off the front cam caps to ad sealant without snapping the cams?
So I took off everything to get to the cam seals and this is what I found.20170527_163835.jpg
Seems to be oil leaking from both seal. The backing made this more evident as you can see from the picture. Now following the advice posted here. The front cam cap should have a bit of sealant on it. There isn't any on this head. So I'm just going to use Ultra Black RTV on the mating surfaces. I couldn't find any 3-Bond orange. 20170527_163742.jpg
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
