Hey guys, its that time =/ Wasn't planning on selling until next year, but nothing ever goes to plan does it lol really sucks knowing there's a possibility of selling, this was my first car, Its still my baby :) so if by any chance you do like the car, and do want to take it, you gotta take care of her !
anyway a bit about the car
IMPUL Body kit with IMPUL badges and strut brace
18 Inch bronze Works CR KAI rims (gutter rash)
Adjustable coilovers
Pioneer LCD touch screen/DVD, Pioneer sub, Boss Amp
Clean stock interior (apart from LCD)
3inch 5zigen exhaust
Xenon Adjustable headlights
Genuine Skyline floor mats
Deep cycle battery (with digital meter)
Aftermarket extractors
Exedy cushion button clutch
Previous owner says its been dyno'd and tuned it to 159KW but i never bothered to make sure of it. Didn't matter too much to me honestly.
It does have a crack on the front bumper and scrape on the side skirt
I planned on fixing it but i just put waterproof tape over the crack and you can barely see it. I dunno maybe I'm just blinded because i love the car :P
Its on 127k km and not daily driven (i catch the train to the city to work so i only drive it on weekends and occasional Friday night)
5
4
3
IMAG0051
IMAG0029
IMAG0020
IMAG0021
IMAG0022
IMAG0024
I also have a replica R34 GTR wing and R34 turbo brakes i bought to put on but haven't yet . and other bits and pieces like carbon fiber eyelids and carbon fiber door scuffs. I'm more than happy to include all these items if it sells for what i'm after.
I'm Located in Canley Heights NSW
Looking at 13.5k neg. Just send a text or pm me as i will most likely be at work :) thanks, Corey - 0422 351 687
https://www.sau.com.au/forums/topic/448989-for-sale-r34-25-gt-manual-coupe/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
