Is that with a 6766 ?
Would love to see a see a graph to compare with my 6266
That it is mate. Nice turbo. We use to have a T78 on it but decided to try for some more power as Yavuz at Unigroup kept telling us there was something that seemed to be holding the power back.
Put this turbo on and picked up quite a bit of power and about 8mph which is decent
Have you had it down the qaurter mile ido9s? Is it fairly responsive on the 26 or abit laggy?
I have. I cant drive for crap but the car has run 11.00 with a best mph last time out of 138.5. Will be back out this Saturday with some new tyres to see if i can run a 10 with it.
I think its responsive but having said that the car has had big singles on it for years so i am used to it.
If your worried about lag go the 6466. The graphs above show the difference and had i seen that i would have gone the 6466. I ahve never been able to find a direct comparison as good as that one. Its quite eye opening to be honest
Weapon X, so there wasnt much involved with those 2 graphs other than swapping out the turbo and a little bit of timing? Nothing else got changed? What sort of boost was it running and what fuel?
Edited by ido09s
No other changes just a bit of timing maybe 2 degrees. Pulled the 6766 put on the new 6466 . Same day or night I guess it was late. lol
Boost is 24 psi. fuel is 93 oct we have in the USA. But the nonEthanol 93 is going away
  • Like 1
Just did a tune on my rb25/30, 6466 t4 twin gates, 6 boost on e80% and it did 520rwkw on 29psi, 420 on 18psi... Unigroup dyno - stupid amounts of torque and lights up every gear up to 4th on 265 AD08r's response is better than 6766 based on comparisons on supras in the US. Just top end is better on 6766 when its pushed hard.
graph?
your not heading back to Unigroup any time soon are you? We made 485rwkw but we stopped at 24psi and would love to see your graph with ours on the same sheet. Only difference is ours is a 26 bottom end
I am quite disappointed to be honest in how ours makes its power. Unfortunately i am limited to 24psi due to standard head studs and with the way ethanol fuel is possibly heading i am not really wanting to disturb the head and stud it as it may not be available in the long run.
I had it back out at the drags a week or so ago and it didnt go any better. 60 foot is down ever so slightly due to new tyres, but it just wont run the first half of the track well. Still runs mid 130's mph wise, but it wont run a decent time. 11.3's pretty much all day
Edited by ido09s
  • 6 months later...
Hope To have a result to post up here in the next month. Built 2.8 stroker with a 6766 1.0 rear on E85. Will be pushing it till the turbo has nothing left.
Did you end up getting it on the dyno legzy?
I see what your saying alot of people like the response and midrange when looking for a turbo, this video is on a rb26 running 22psi it's doesn't seem laggy.
A 6766 on a rb30 would be even better and with more boost [emoji3]
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
