Hi everyone,
All the following parts are from my 1995 Series 1 R33 GTR V Spec, following a recent upgrade.
Please refer photo's for what's included with each item.
DBA 4000 Rotors (4298SL) Front (when new 324mm x 30mm) Rear (new 300mm x 22mm), with Endless CCX pads (BL12BL rear, BL09BL front), stock R33 GTR callipers & lines. $1,400.
Stock R33 GTR twin turbos, off running engine set to 1 bar boost. Minimal shaft play & appear pretty good condition. Includes actuator, dump pipes & heat shields. 85,000kms old. $200.
R33 RB26 14 x standard head studs. $40.
R33 RB26 6 x standard injectors. $60.
R33 RB26 water pump. $20.
R33 RB26 oil pump. $90.
R33 RB26 6 x pistons & 5 1/2 x rods (No freakin idea what happened to the other half of the rod! Turned my place upside down looking for it.) $100.
R33 RB26 6 x standard coil packs. $100.
R33 RB26 cam gears. $40.
R33 RB26 tension & idler pulleys. $50.
R33 RB26 standard harmonic balancer. $50.
R33 RB26 crank angle sensor. $150.
HKS EVC IV (Electronic Valve Controller/Boost controller). $290.
R33 GTR Power FC & hand controller. $700.
I live in Rockdale NSW.
PM me with any further inquiries.
PM's replied. A lot of interest in the Brembo's.
Initialdennis I will separate if someone doesn't buy the whole setup.
Nice teamwork guys, I have an interested buyer looking at them tonight. If unsuccessful I'll let you know.
Initialdennis, I went AP Racing & have never looked back! But as always it's dealers choice. Good luck hunting.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
