hey guys, its my first time swapping a turbo on anything other than sr20det.
few months back decided to get this rb25 turbo, i swapped it in, having to make a nipple/bung on the intercooler piping close to the turbo(because the 20 turbo has one on the compressor housing for the wastegate.)
Soo i start this thing up and take it for a spin, also whats noteworthy is i kept the rb20 actuator, it worked fine before and they hold more psi soo installed it on the rb25 turbo, when i tried to do a pull, i notice there is noo power at all when i get into boost, like feels even slower than if there was no turbo at all. i can still here BOV after closing throttle, but its almost always now accompanied by a backfire. I also stall just about any time i go into neutral from cruising.
I tried checking for vac and boost leaks, i cant find any, boost gauge doesnt spike or drop pressure when im on the throttle heavy.
theres no misfire or bogging under pressure, only the absence of power, and i can tell its running richer now too, despite no wideband at the moment. I can smell it. and not to mention all the backfiring.
I have even got another great condition low mileage 25 turbo since then and the same thing occurs.
My car ran strong before swapping the turbo chirping 2nd gear pretty hard. now i dont even think i can pull a toyota corolla. it is seriously soo slow.
the gaskets looked good when i swapped the turbo as well.
I am soo lost on this.
Sounds like a leak, otherwise your turbo may not have liked the extra boost... In which case call Hypergear.
Trusting in S/H turbo's will bite you in the ass most of the time.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
