How's it going guys,
The names Andrew people call me Andy or Mex
I'm 20 and long time lover of Jap cars and motorbikes
I own a 1995 Honda Integra and recently (yesterday) purchased a 1993 HR32 Skyline
The skyline needs a lot of parts but the engines good, gearbox smooth and clutch is great
You'll probably see me around posting for parts and probably asking a lot of help on how to do things ^_^
Cheers guys an gals
Follow me on Instagram if you want - andrewmaiorana
https://www.sau.com.au/forums/topic/449750-hows-it-going-guys/
