Good idea!
What is actually happening is air is being forced in :P
The M35s have the zero lift aero design which actually generates some reasonable vacuum under the car. Right at the base of the windscreen is a high pressure buffer area, which would force cleaner air into the engine bay. These two working in combination would be helping to draw some fresher air into the engine bay!
Good work!!
Maybe. Or the air being forced the back in makes it harder for air to go through the radiator.
Fortunately not, the combined frontal positive pressure and combined undertray negative pressure is combined greater than the high pressure at the base of the windscreen. It will only stunt radiator flow a little bit, nothing worth worry about.
Maybe.
My only issue is that you are guessing.
I don't need data to call you out for guessing though do I?
Here's a question for you .
How much cooling affect does an engine get from air generally blowing over it vs the actual radiator?
I don't know. But I would have a guess ;) and say the air though the radiator is way more important.
I think maybe you misinterpreted my first post. Not trying to be argumentative here either.
I like his idea, I personally think it would work well as its removing heat from a critical area of the engine bay that sees very large amounts of heat saturation. This would have small benefits to hoses and component life in that area, as well as manifold heat soak would be brought down a little.
The reason it would work well in my opinion as its effects would only become valutive at higher road speeds when a reasonable pressure system can build at the windscreen base. At the time these speeds are achieved the radiator system at the front of the car is already achieving the maximum transfer of heat from air speeds. The only way the radiator system could become more efficient at this point is if the ambient air temperature was to become lower.
Thanks Dale. That is a pretty good temp compared to mine. I don't have a nismo thermostat as yet. I have got a 53mm aluminium radiator, except when i installed it i didnt trim enough of the shroud off so when driving it for the first time after the install, when i came off boost the engine lurched forward and plowed the clutch fan into the shroud and thus destroyed both...so i installed twin thermos in a sealed shroud i made up. So until i can get my hands on a decently priced shroud and clutch fan i have to live with the davies craig setup.
On another note: i put the undertray back on today for the first time since i bought the car. Water temp is between 90-93, so 1 deg higher on the lower running temp;same on the higher end. Intake temps were lower!!! I think this is due to more air being channeled into the cold air intake (ducting next to the I/C).
pics of shroud and how the thermos are mounted ?
there is a wrong way of mounting thermos which will block air flow
Thanks for the input guys.
I have had the bonnet like this for a little while now and although it is drawing air in at the lifted point I am not experiencing any temperature rise in any driving situation. I am in fact experiencing a temperature loss and improved drivability. I am not recommending anyone else to or not to do this, I am merely posting my experiences, and as dale said earlier, it is just another version of whats been done before.
I am yet to get my hands on the appropriate equipment to monitor the pressures, but when i do i will post up the data.
To add to DMMs discusion points, before i lifted the bonnet i could not keep my hand on intake manifold at all. Now, after a spirited drive i can keep my hand on it as long as i want - still feels warm, but not nearly as scolding as before. So i'm guessing that the heat from the exhaust manifold that wraps around the back of the motor is being extracted rather than heating up the intake.
I'll take a pic of the shroud in the daylight, but i am still convinced that the clutch fan is a better option.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
