RB20 speedo drive is a mechanical drive at the gearbox, with mechanical cable to the speedo head, where the speed sensor (for the ECU and HICAS etc) is located. If you meant "speed sensor" as in "speed sensor" then it is in the dash. If you meant "speed sensor" as in "speedo drive" then yes, it's in the gearbox.
Both the CA and RB20 boxes are mech speedo drive. You will need an RB20 box's drive. I wouldn't expect the CA one to fit the RB box. Might, but wouldn't count on it. With luck though, an S13 cable might connect to the RB20 drive.
This has been done many times though, so I'm sure the info on what you actually need to do is out there.
Wrong
CA18DE/T uses an electric speed sensor
I converted my 180SX with a RB20DET many many years ago and used the CA18DET sensor and even gearbox mount on the RB20DET gearbox
Worked tits
Apparently it's not pouring oil out everywhere so probably has the speedo cable still there but just cut off.
Should be a keeper plate with a 10mm head setscrew holding that in place.
Once the keeper is removed, the cable drive unit will pull out from the extension housing.
Do a tooth count on the pinion so you'll have an idea if the speedo is out.
R32 should have had 4.3 diff as would the S13 so things should be OK.
Push your electronic unit in and fit the keeper plate.
Connect up the plug, hope for the best.
Your 20 ecu will need a speed signal, wiring been done?
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
