RB20 speedo drive is a mechanical drive at the gearbox, with mechanical cable to the speedo head, where the speed sensor (for the ECU and HICAS etc) is located. If you meant "speed sensor" as in "speed sensor" then it is in the dash. If you meant "speed sensor" as in "speedo drive" then yes, it's in the gearbox.
Both the CA and RB20 boxes are mech speedo drive. You will need an RB20 box's drive. I wouldn't expect the CA one to fit the RB box. Might, but wouldn't count on it. With luck though, an S13 cable might connect to the RB20 drive.
This has been done many times though, so I'm sure the info on what you actually need to do is out there.
Wrong
CA18DE/T uses an electric speed sensor
I converted my 180SX with a RB20DET many many years ago and used the CA18DET sensor and even gearbox mount on the RB20DET gearbox
Worked tits
Apparently it's not pouring oil out everywhere so probably has the speedo cable still there but just cut off.
Should be a keeper plate with a 10mm head setscrew holding that in place.
Once the keeper is removed, the cable drive unit will pull out from the extension housing.
Do a tooth count on the pinion so you'll have an idea if the speedo is out.
R32 should have had 4.3 diff as would the S13 so things should be OK.
Push your electronic unit in and fit the keeper plate.
Connect up the plug, hope for the best.
Your 20 ecu will need a speed signal, wiring been done?
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
