G T - R Magazine In Town --- Article On G T - R Popularity
It's just come out in Japan to-day. My friend Nick got one. Lots of Aussie JDMs! Gold!
Kinokuniya won't get them until Wednesday 10th Dec.
Nick may bring some back at a lesser price than Kinokuniya if you're interested!
Nice feature guys!
I picked up two copies while I was in Shibuya this morning (both spoken for)
If there is some genuine interest I can try and find some more before i fly home tomorrow.
Nick
  • Like 1
Thanks Blitz for the photos. For me it is an absolute privilege to have my car appear in GTR magazine, and I very much enjoyed talking with Yamazaki San and Masuda San about their GTR's, particularly their V spec 2 Nur.
I would like to thank JLM for organising a day that all who attended will never forget. Those of us who take our cars there already know that the quality of work carried out there is of the very highest standard and it is great to see them getting recognition on an international level.
  • 1 month later...
Next to my car, I'm quoted as saying,...
* Skylines Australia organised the 25th Anniversary of the R32 GTR in August this year.
* Skylines Australia has a splendid future.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
