So i either didn't receive an instruction manual with my gauge kit or i just lost it, anyway
could someone enlighten me on how the wiring works in this particular setup please ? (which is what)
so far i have the vacuum hose routed to inside the cabin and just need to wire this thing up
but am having difficulty without this manual
Edited by DN14
https://www.sau.com.au/forums/topic/449881-boost-gauge-wiring/
Correct me if I'm wrong guys.... Red = positive! black = ground and green = boost signal.
I'd get 12v power to both ground both blacks, then connect the green from solenoid to the green on the gauge. :)
WTF, has it had a 9v battery hooked up to it at some point?
Looks pretty sketchy to me, Personally I'd buy another gauge but thats just me.
Anyway, as above, red - Power, looks like its supposed to tee in where the 9v battery terminals are. Black will be ground, but not sure if you have to earth it or if it earths through the MAP sensor mount. and green just hook up to the other green. My gauge has 2 seperate plugs, one is the 3 wires back from the gauge, and the other is power, earth and illumination
yeah i was surprised to but the battery was there for demonstration purpose, outside the box theres a "test me" button
currently confused were to earth now lol
yeah they were all like that picked it up from repco, its Autotecnica
anyway earthed to lighter socket all seems working fine
You can connect the black cable to any metal point in the vehicle. I generally use the metal dashboard frame and place the black wire under a screw. :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
