So i recently purchased an m35, knowing it had an overheating issue. I knew it would 99% be headgasket blown! Only 70km on the clock.
Thankfully the motor looks on great nic on the inside! I was also happy to note that the coolant didnt blow through into the oil galleries - which has made the repair job much easier!!!
These things are built tough, ive played with vq35's a hell of a lot previously and RB's. I am falling in love with the design of these motors. Thick sleeves, large coolant volumes around the sleeves which the 3.5 block doesn't have. Good pistons.
That centre blanking cap in the middle of the valley I think is used for a coolant control valve in the US market? Inside mine looks to have boiled under there and acted as a small air lock. I'm going to link from here and the factory bleeder valve to a bubble tank - hopefully alleviating air lock issues in the future!
https://www.sau.com.au/forums/topic/450283-dreaded-vq25det-headgasket/
Scotty_m35 makes a bolt up coolant mod that works similar to the us version and also has a nice bleed valve added in. We'll wprth the investment
Any pics or links to the system he uses? I am just about to order an fittings and weld ons.....
Search the forum for scotty's m35 coolant mod.
Pretty reasonably priced for the product and the quality of his workmanship.
Also Google scotty's customs. He has a website and produces a lot of bolt on m35 parts that are proven to produce the goods.
Also look at his dump pipe, it's the best there is
Oh, to answer the question on the extra coolant gallery, it was a feature on some of the other motors in some of the other motors inthe VQ range, that part of the "towing package" would feature an additional coolant passage with separate thermostat.
Here are the parts :)
http://www.z1motorsports.com/350_g35/product_info.php?products_id=3011
Good job opening it up, and sorting out the issue btw.
Except those parts won't fit the M35. ;)
Overheating doesn't mean the head gasket is gone in these, so anyone reading this later, check you have properly bled the cooling system, or fit my coolant mod kit before ripping the engine out. Please. It will save you a lot of headaches.
  • Like 1
Definitely not, plus the outlet pipe to the radiator is completely different.
No idea why you would need another two thermostats either, just another part to fail.
My kit uses the heater line to bypass coolant from the block, rather than relying on the one small pipe at the back of the engine. It also replaces the plastic bleed assembly with alloy which is another common failure point.
Correct! However - these being open deck - often will warp the heads. The whole VQ range from my experience does not suffer to well under heat - ive seen them where they even warp through the cam tunnels!!!
Of course i didnt just take a punt - i knew it was head gasket before ripping it out.....
Often? I've had mine at 150C at the track on many occasions, it never lifted or warped the heads, even at 40psi up the straight... Being alloy block changes things, as the expansion rates are similar, unlike iron block/alloy heads.
If the heads are warping that bad there is an airlock causing no coolant to flow, which is the common VQ fault I tried to alleviate with my coolant mod design. As the bore and heads overheat they cause flash boiling which exacerbates the problem.
Well when you are running ARP head studs i would hope you don't have issues!!! FYI i've gone back to OEM studs - ditched the angular torque and run my own torque values (105NM final value). Angular torque on a used block is a waste of time and generally ends in uneven torque values.
The issues with OEM bolts and open deck comes down to contact surface area. Nothing to do with iron alloy mixes....that wasn't even on the pallet for discussion haha. Like you say - flash boils - but the residual heat in the open deck decreases the dynamic torque of the studs and allows warping and reduced pressure between bolt spreads. When the pressure between the cylinders lifts obviously they blow through. I have never actually seen a VQ blow through on the outside of the open deck and lift to an adjoining oil passage - always happens middle of block between coolant chambers.
I've blanked off my radiator cap. Fitted my own bubble tank with the pressure cap, teed off from turbo water feed (base of turbo), centre of valley, teed off top of thermostat and bridged and removed OEM plastic bleeder.
I must say however I do prefer the VQ25 block over the same era VQ35 blocks. These blocks are much more boost friendly with a thicker sleeve and larger volume coolant chambers surrounding the sleeves. Also the OEm metal gaskets are very good - however I don't like they fact they pre coat them with the teflon/graphite mix. I threw mine in the light costic wash for a few hours to get rid of the coating :)
Edited by DMM
Could you give the reasoning behind not wanting to use angle torque on a used block?
It is my understanding that angle is used to remove the error caused by varying amounts of friction acting on the thread, interfering with the actual clamp load and stretch of the bolt.
How does the block being used negatively affect that?
I only fitted the ARP's after running unlimited boost, lifting a head. I also ran the car hard for a year before the head gasket finally let go in a big way on the dyno. Like you say the extra meat of the bore is what helps us VQ25 guys, comparing it to the VQ35 is silly, they are very different as you have found.
OEM gaskets here, with extra Hylomar spray. 105nm sounds like a lot on stock bolts...they will have twisted nicely. Did you lube the threads at least, and clean the threads in the block?
Ive found in the past angular torque stretches the block threads heavily. There have been some situations where a customer has requested a certain bolt with angular torque and it pulls the thread. The only way i've found against this is using helicoils to increase thread depth contact area. Mathematically when you use stretched alloy the thread bolt only touches around 60% of possible mating thread in the block.
If it was all brand new then nothing wrong with angular as yes you are right - helps eliminate error.
No twist - prepared in layers. Cleaned and oiled of course. Process as follows:
1)Spun bolts in and out 3 times to distribute oil evenly and wipe off excess after each spin.
2)Check block temp - anything over 25degree at 0.15% NM for every 1 degree over 25.
3) Torque all bolts to 65NM. Let gasket squish and settle.
4) Torque to 90NM - let set over night
5) Release bolts, remove and check oil coverage. You will see ghost marks on bolts if oil coverage is poor, otherwise will have nice even moist look.
6) Nip to 90NM again - just touch 90, no need for high tension load.
7)Torque to 105NM and finished.
No bolt groan, no binding, no twisting process! Used this many time over the years on RB, SR and VQ engines. A lot have seen the loads of bathurst etc without engine failure.
It won't matter how tight the bolts are done if you don't fix the coolant issue. Surely you would have known about that with your VQ racing expertise?
I chose to do my bolt tensions that way to reduce twist or shift. Not to stop a head gasket from lifting. Gaskets are designed by nature to be the weak point.
Coolant issue is as you have said - failure to flow out the back of the block/heads. The two passages out of the rear of the heads are tiny and restricted from flow heavily. This is why is I'm adopting the centre relief in the valley to help with flow.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
