  • Replies 52
Do you know if the head still will fit a RB25DET VVT model inlet manifold. I think there were two designs in the non vvt heads one will and one wont fit an inlet manifold. Am thinking of doing a head with GTR cams and solid lifters so dont need the VVT. However I need it to fit the manifolds from DET motors.
Thanks
Hey mate
Yes the DE head does fit a DET head but uses some differnt lines and stuff. Have a look in the RB30 R33 build up in the Forced Induction section for more info.
Take it easy.
Adm
  • 3 weeks later...
  • 2 months later...
  • 3 weeks later...
riceline: can you pm me your mobile number (i think i have it already, but not 100% sure - got it off someone else who bought an inlet manifold off you a while back)
i'm interested in the plenum, the 25DE exhaust manifold, and whatever else you have lying around. need stuff for the top half of my 25/30DETC build. you haven't, perchance, had the plenum flow tested or anything have you? and who built it?
  • 4 weeks later...
Hey mate,
Do you still have the NISMO F.P.R.?
Thanks champ
Hey guys
I have a Heap of parts from my RB30 build up left over that I'm keen to get rid of. Sick of the space that they are taking up in the garrage. If you have offers please send them my way.
Once most of the parts are gone I will be Donating $100 to SAU as a thanks for all that SAU Provides for us.
Donated $10 So far
RB30 Piston rings (5 Only All complete though) $30 (cost me $90)
RB30E exhaust manifold - $Make an Offer
R32 RB25DE TOP FEED injectors $50
R32 RB25DE Non VVT head (No Valves or Lifters) Timing belt Cover, CAS Bracket, Cam gears and rocker covers $200
RB25DE bottom end (has Sump, Oil pump, Engine mounts - No Oil pressure sensor, Harmonic Balancer, Dip stick holder or Dip stick) $150
RB25DET Bottom end (Block, Pistons, Rods, Crank and Cradle) Replaced due to RB30 Upgrade - $200 - Sale pending
RB30E Head - $50
RB30 Inlet manifold Complete Inlet, Plenum, Throttle body and fuel rail - $20
RB30 Engine Mounts - $20
R33 GTS-T Custom Plenum $320 (I have not used it. It is still in box from when I first recived it in the mail. Purchased from the fourms. Has Plenum, Throttle body, TPS, Inlet manifold gasket and all bolts. Bolts onto std R33 inlet runners) - Sale Pending
R33 GTS-T 3Inch Turbo to Cat Dump Pipe wrapped in Heat Wrap $200 (Has not been put onto my car as it would not clear the undercarrage because of my RB30DET set up. Fits perfectly to a RB25DET)
Nismo Fuel Pressure Regulator - Universal/z32 style - $100
Thanks guys
  • 1 month later...
Hey guys few responces
BigCarl : No sorry mate - not as of yet still have to get my new ones. will put them up when i have my new ones in though
Bobjones: Sorry mate Sold
Daler32: don't think it will mate. But i will see what I can find out
Luke33gtst: don't have one sorry mate
Thanks guys
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
