Hello,
Taking the v35 to a mechanic next week, but would like to know if anyone has had a similar problem and would like to know how much im looking at to fix.
Out of know where the VDC, SLIP and Immobilizer light all came on, power is reduced, (seems like it is in limp mode, revs will not go over 3an a half) and it is very irritating.
I have tried disconnecting the battery, checked brake pads and all fluids, was not doing any irrational driving so i cannot understand why its happening.
After the car is turned off for at least 20 mins, and switched back on the only light that is always on is the immobilizer which is stock, then with out fail they all go back within about 10 mins, and no power again. The car will then hesitate to start whilst those lights are on.
Anyone at all had something similar happen?
Appreciate the replies. :unsure:
was driving home yesterday and the oil pressure light came on at idle and car stalled.. maybe that could be why its going into limp mode/slip light coming on. Major service was only done in november with the oil and filter changes, so i hope its not the oil pump and just a sensor, not hearing any unusual sounds either.
yeh oil level is fine, im in canberra, just really wanna make sure it will be ok to drive to the mechanic on wednesday, the light only came on once like a said they car stalled, i started it back up and made it home without it coming on again which is a 30 min drive, 40 mins to mechanic though
Happened to my 350 coupe once before I bought it (mate's car). Sounds like exactly the same problem you encountered i.e. VDC/SLIP on, car in limp mode... Changed a cam sensor and things are all good but that's just for me. Take it to a good mechanic and put on Consult III definitely.
Yep.. mine did exactly the same thing, but was caused by a bad connection on my after-market cruise control, which threw a 'accelerator pedal sensor' fault. So certainly needs codes read to know the cause.
no worries thanks for the input guys, yeh hope thats all it is, the mechanic specializes in skylines so i hope he will do. Excuse my ignorance but what is a Consult 3?
The only light that remains on the whole time is the immobilizer.. so did it stall and oil pressure light come on for any of you when SLIP light was on?
Consult is Nissan's diagnostic system, consult3 is the most recent revision, this is what Nissan plugs into your car to diagnose issues.
There are several consult3 clones you can buy to do the same job.
Even some basic diag tools can do simple tasks like read error codes. I used Nissan datascan to check the code when I had these symptoms.
  • 1 month later...
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
