Hi
Selling my gizzmo kmon.
Included is one knock sensor and a custom fitting to allow it to be screwed into the stock location on rb engines.
Monitoring knock is critical when tuning, and this works very well. Adjustable filters make it so simple to isolate knock from other noises (there are heaps!) And adjustable alarm and sensitivity etc.
$420 negotiable delivered express.
http://www.sau.com.au/forums/topic/176922-gizzmo-k-mon-the-best-tuning-tool-you-will-ever-use/
Ben
PM or mobile.
Pics available later, if required.
Edited by R31Nismoid
https://www.sau.com.au/forums/topic/450590-gizzmo-kmon-pro-knock-monitor/
Ughh. Do want but low on cash at the moment. Any idea if you can use the bosch knock mics that come with it to feed aftermarket ECU's? Not sure on how good the old nissan ones are and they want $130ish for a single one brand new. Would much rather spend my money on something decent like this.
It has an output that apparently can be used to datalog, however I never used that feature.
I'm not sure if the knock sensor on its own would work well with an aftermarket ecu. I'm also not sure how good the knock detection ability of aftermarket ecu's are.
Still have it.
Tune your car's people!
E85 still knocks..... just not as loud. Think of your bearings. .. Buy this. Look like a professional.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
