Going by your details as posted above Merli, unless you're talking about drag racing that drop between 1st and 2nd is pretty much irrelevant.
If talking track, 2750 between 2nd and 3rd is a much smaller powerband and even that would only be used at a tight track like Wakefield.
A consideration maybe?
I wish I knew what my ratios were.
:thumbsup:
  • Replies 53
:thumbsup:
Well................... not really :D :D
Are you saying that you only use 5750-8500 rpm whilst driving on the track? Often it's not feasible to change down a gear to keep it in that rev range...
Example:
A tight corner that should be taken in 3rd gear at about 5000 rpm can't be taken in 2nd gear, as that would equate to 7500rpm in 2nd gear (with R33 GTR gearing). You'd actually lose time in the extra two gear changes needed to use 2nd gear into and out of that corner, and you'd only be in 2nd gear for about 0.5 seconds as it revs from 7500-8500rpm anyway.... Make sense?
In reality, you'd be aiming to have a strong 4500-8500rpm range around the track...
Oops, sorry mate...
Here are the gear ratios for the R33 GTS-t Auto box... The R34 Tiptronic is just an automatic gearbox, so I assume it would be the same ratios as the R33 Auto?
1st - 2.785
2nd - 1.545
3rd - 1.000
4th - 0.694
Final Drive - Dunno, probably 4.111
:cheers:
lol, I have an R34 RB25DET that I'm swapping into my 89 240sx SOOO i found the gear ratios for the GT-T and got the answers..... assuming your car is manual transmission
Engine speeds in top gear:-
30 MPH = 977 RPM 40 MPH = 1303 RPM 50 MPH = 1629 RPM 60 MPH = 1955 RPM
70 MPH = 2280 RPM 80 MPH = 2606 RPM 90 MPH = 2932 RPM 100 MPH = 3258 RPM
Top Speed in 1 gear = 37.574 MPH
And changes into 2 gear at 4000 RPM dropping 2800 RPM
Top Speed in 2 gear = 63.876 MPH
And changes into 3 gear at 4338 RPM dropping 2462 RPM
Top Speed in 3 gear = 100.120 MPH
And changes into 4 gear at 5015 RPM dropping 1785 RPM
Top Speed in 4 gear = 135.763 MPH
And changes into 5 gear at 5181 RPM dropping 1619 RPM
Top Speed in 5 gear = 178.176 MPH
And changes into 6 gear at 5804 RPM dropping 996 RPM
Top Speed in 6 gear = 208.746 MPH
oh yeah, ignore the 6th gear (obviously)
Well................... not really :):rofl:
Example:
Shoot Merli, you really have got it :cheers:
  • 1 month later...
That seems simple enough... Cheers!
But after a bit of simple maths, I've worked out the revs drop for each gearchange for an R33 GTR :P
Gear Change Rev Drops (rounded for simplicity)
1st-2nd    3410rpm (8500rpm -> 5090rpm)
2nd-3rd    2750rpm (8500rpm -> 5750rpm)
3rd-4th    1970rpm (8500rpm -> 6530rpm)
4th-5th    2110rpm (8500rpm -> 6390rpm)
So R33 GTR owners should be aiming for a powerband between 4500rpm -> redline (taking into account poor drivers holding you up)... Is that right?
Makes sense... I can understand why people consider GT2530s perfect track turbos for the GTR, since that pretty much fits the required powerband prefectly! ;):)
Very interesting, thanks!
Andrew
Try this
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
