I have a 1993 Nissan Skyline GTR R32 up for sale or swap. I'm over the car, it's my second one and I want to buy a series 5 fc Rx7 as I've always wanted one. Or something newer and more comfortable. Car was also originally bought from another member here about 4-5 months back now?
-Built 2.7L motor, sleeved to accommodate 88mm CP pistons
-HKS Step 2 rods and bearings
-ARP headstuds
-HKS Camgears
-GREDDY staggered 262/272 camshafts
-N1 oil pump
-R34 gtr crankshaft
-Custom 8L baffled sump
-PAR straight cut gearbox 1st-3rd
-GATES Timing belt and accessory belts all round
-Brand new century battery 1 week old
-Custom oil catch can
-750cc injectors
-New spark plugs bcpr6es-11 gapped to 0.8mm
-twin entry fuel rail
-Sard fuel pressure regulator
-Oil cooler
-Hks mushroom pods
-Z32 afm
-Oil filter relocation kit
-3inch turbo back exhaust
-Aftermarket aluminium radiator
-Aftermarker front mount intercooler
-Bosch 044 external fuel pump and surge tank
-Nismo shift knob
-Autometer boost, oil temp and oil pressure gauges
-greddy profec spec 2 boost controller
-Apexi power fc ecu with hand controller
-Tein adjustable coilovers
-Rear diff bushings have been changed
-Hicas disabled electronically
-Rebuilt r33 n1 turbos
The car used to make 340awkw but atm is running 252.8awkw on Incar's dyno on 14psi, it's got potential for alot more but turbo seals are on its way out so it's on a conservative tune. Plan was to throw on a gtx3582r and push over 400awkw but over it and want to trial out something I've always wanted before I buy an r34 gtr. I have also a spare power fc d-Jetro with map sensors and loom that was bought for the single conversion but not used. Also forgot to mention it's got a brand new bm57 Bmc in it as I was going to throw on evo brembos in preparation for the power it was going to make. The body's fair for its age and the interior is pretty immac if you consider its only got a tiny bubble compared to my previous gtr.
If the new owner wants to go down the same route and get the brembos, i can get them off my mate for you for $700 front and rear, and $1100 for d-jetro with brand new hand controller never used with map sensors and wiring harness.
It's got almost full year rego, 10 months from today pretty much and looking for a swap for a clean series 5 fc Rx7 with cash my way and I know what they are worth or $22000 Ono for my gtr and for what it's got its a very fair asking price and I'm also nego. Oh forgot to add, there's an entire folder with dyno sheets and receipts for all the work done to the car.
Car can be arranged to be viewed at Anytime during the week as I also currently left my job last Saturday. Located in Fairfield, contact number 0422 one two six 939. Strictly no tyre kickers or joy riders, test drives only when deposits taken otherwise ill take you for a spin thats IF you seem like a genuine buyer. Im still on the rocks in regards to selling it since theres not many series 5 rx7 on the current market i like so dont bother trying to low ball me im not in a rush. Ill consider fair negotiations with genuine buyers.
post-75344-0-14156400-1416715867_thumb.jpgpost-75344-0-52713800-1416715873_thumb.jpgpost-75344-0-03451000-1416715881_thumb.jpgpost-75344-0-64591500-1416715887_thumb.jpgpost-75344-0-70991300-1416715894_thumb.jpgpost-75344-0-05140100-1416715903_thumb.jpgpost-75344-0-52167300-1416715913_thumb.jpgpost-75344-0-29127500-1416715919_thumb.jpg
Edited by _Dee
https://www.sau.com.au/forums/topic/451003-wttwts-93-built-27l-r32-gtr-syd/
  • 3 weeks later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
