good afternoon all.
something a bit different for you, if your into that sort of thing.
My daily driver ute needs to go for a sedan.
its 8 months old and basically brand new.
it also has a bit of work done from brand new so all warranty in tact and no hassels!
read and enjoy:
Car: 14March built MY14 VF SSV manual ute
PRICE: 43500.00 (cheaper with parts removed)
YEAR :March 2014 built
SERIES: VF
BADGE: SSV
ENGINE: 6.0V8
TRANSMISSION: 6 speed manual
COLOUR: Herron white
EXTERIOR CONDITION: brand new
INTERIOR CONDITION: brand new
WHEELS: 19"
ODOMETER: 12000km
SERVICE HISTORY: serviced (also has capped price servicing for 3 years)
REGO OF CAR: rego until march 2015
RWC: na
DELIVERY/PICK UP INFORMATION: can be sent aust wide
PAYMENT OPTIONS: COD, Direct Deposit, Funds Transfer
CONTACT DETAILS: 041314543o
OTHER INFO:
the vehicle has the following modifications new from Holden, all are covered under factory warranty:
Tinted "street legal special" tint
Walkinshaw 310kw power-pack including:
ceramic headers through to full exhaust
OTR cold air intake
Walkinshaw retuneed ecu
Holden dealer fitted
full Holden warranty certified
Pedders coilover suspension system:
base height adjustable
damper adjustable (32 step)
full warranty
HID Xennon headlight upgrade 6000k
LED matching foglight replacements
full warranty
Full blackout exterior upgrade:
front facea black inserts
foglight surrounds black inserts
side vents black inserts
black mirrors
Stub areal
roof wrap can be removed if preferred.
all stock parts can be supplied if wanted including suspension, exhaust, intake, front and side moldings, headlights ect.
link to car sales ad: http://www.carsales.com.au/private/details/Holden-Ute-2014/SSE-AD-3098071
PICTURES:
a few pictures i have atm, lots more available but test drives and viewings welcome, but we will not be going for a "thrash" trust me.
enjoy, ask any questions you have
cp5635338779049420630.jpg?height=700&aspcp5260360667964885859.jpg?height=700&asp
cp4741871553231363853.jpg?height=700&asp
cp5581055354950481982.jpg?height=700&asp
cp5628469159093093502.jpg?height=700&asp
cp5480718751589929649.jpg?height=700&asp
cp5058486006573673581.jpg?height=700&asp
cp5096654636728633518.jpg?height=700&asp
cp5690075740594783253.jpg?height=700&asp
cp4842618457314587544.jpg?height=700&asp
cp5514687826956226889.jpg?height=700&asp
cp5027462394495610580.jpg?height=700&asp
cp4886510102233424921.jpg?height=700&asp
cp4850983446567153600.jpg?height=700&asp
feel free to call me
thanks mate.
i thought it would have been snapped up seeing as its a $50k car with $13000 spent 8 months ago, but we will see.
as soon as it sells im getting a 32gtr.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
