For Sale
4 X YOKOHAMA S DRIVES TYRES 255 40R 17
TO SUIT 17 x 9 RIMS
Only done approx 4,000km
Heaps of tread left (tyres came off my R32 GTR two day ago)
These are good quality and were on my GTR
$500 for the lot
Located Gold Coast Arundel
Happy to freight anywhere in the world at buyers expense
0404 006 580
10700386_1559101504326090_83422523133639
1548204_1559101634326077_870740205525743
10426154_1559101630992744_36243991344411
10517661_1559101587659415_51732993176465
10408724_1559101577659416_26789402717571
https://www.sau.com.au/forums/topic/451376-yokohama-s-drive-tyres-for-gtr/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
