R32 GTR Japanese Import. With Australian compliance plate. Previously registered in Canberra
Huge Trust intercooler,
Z32AFM, Rays Engineering wheels, two are f*ed but the tyres are good (scuffed from track day at Wakefield)
Whiteline suspension.
Upgraded custom front disks and calipers. Spare disks and coilovers (n
Fibreglass bonnet is scuffed but not cracked.
Front bar was off the car and is intact/undaamged
Upgraded turbos - dont know what they are, but there's a Garage Saurus ECU that came with the car, HKS boost controller.
SARD Hard piping. Upgraded radiator,
Tower struts, Body brace.
Lots of goodies. .
IS REPAIRABLE, NOT A WRITE OFF. But you would need new front right guard, Door, glass, and roof section.
I was going to repair it but circumstances have changed.
This car was making 299KW reliably and was leaner on fuel than my stock R32 GTR (which I have sold).
Used to run at Wakefield on club days, and was quick.
Has a lot of nice features including red skyline lettering inserts on the boot.
Had $8000 on it, will take $6 grand cash, not a penny less, and will deliver for the cost of diesel.
Cheesewire restraining barrier at around 15 km/h. Nose went under it, the bruises are from the wire inside the car. Dangerous stuff...
Is repairable... That would need a shit tone of money thrown into it to even get it close to passing rego. Scrap for parts because no one's going to be 6k for a car in that condition.
btw wtf did you do? drive it off a cliff?
  • Like 1
Wire restraining barrier. As I said. Impact was around 15km/h. Nose went under it, the wire took the momentum and swivelled the car sideways.
It is repairable, talked to a panelbeater also a few guys at Wakefield. Parts are available from Japan, around $1700 in new roof, right rear, door pillar panels, $450 for a secondhand door and guard, $200 in bonnet repairs. $2000 in caraligner and another $3.5k in paint. Its a 300kw car, not a stockie. Or part it out and get around $11k in parts.
how does one flip a car at 15kph?
srs question
Wire restraining barrier. Didnt flip. Slid into it, cops reckon someone oiled the road near the corner. Had just changed into second, was stopped at a set of traffic lights at a T intersection.
Or get a car with intact drivers door pillar/roof, drill the spotwelds, they were all machine assembled so welds are in exactly the same place.
Otherwise I will do it myself on the rotisserie.
11k in parts?
Sorry didn't read that part.
Still going to be hard to sell. not many people want to buy a car that f'ed up just to fix it. I'd love to buy it
Wouldn't you get more than 6k if you wrecked it? if you did in fact but 11k worth of parts for it.
Yes I would if I parted it out, would be sad, but I'm located in a rural area and not easy for people to pickup parts.
How much would it cost you to make a reliable 300kw gtr?
Anyway I have an offer, hopefully not another BS artist.
so its been through insurance hence classed as repairable write-off by insurer and not repairable deemed by your opinion?
Yes insured through Shannons, and bought back, its not on the register at all. Hhad a panel beater look at it yesterday, he reckons front tie rod is bent (they are apparently soft), no front chassis damage, unsure about the cradle but probably no damage, there's a small dent in the rear sill chassis rail but is not a fold, so will pull out. A right rear GTR cut, drivers pillar, and new roof, door trim/window, and front side windows. Rear cradle looks OK as well but cant tell until you get it on a hoist and measure it properly.
Sold it and then the buyer changed his mind when he fronted up with his parents ( !! FFS !! ) best offer I've had is $5,500 so will let it go for that.
My new project car is arriving in two weeks (1963 Ford Falcon Wagon) and I need the space.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
