Hi Crew
Details for our next track day.
DATE:
Saturday 10th JAN 2015
VENUE:
Wakefield Park, 10 km south of Goulburn, is a purpose-built closed road track environment which simulates typical driving corners.
PRICE:
Retail is $295 per person
Forum Special
$250
THERE IS A BOOKING FORM ON www.trackschool.com.au
TRACK:
2.2km racing circuit.
VEHICLE:
Use your own vehicle, or hire one of our race cars. Our vehicles available - http://www.trackscho...om.au/cars.html
* 1 x Honda Integra Type R
* 2 x Mazda MX5s
* 1 x Nissan 180SX
* 1 x Ford V8 Ute from the V8 Ute Series
PRICE INCLUDES:
* Max 4 groups
* Plenty of track time
* Well organised
* Pro Instructors
* Free passenger sessions
* $250
GROUP ORGANISATION:
We only allow small groups of vehicles on the track at one time.
Drivers will be divided into groups according to speed and/or experience.
CLOTHING REQUIREMENTS:
Please wear closed in shoes, socks, long pants and long sleeve shirt.
Bring a helmet (helmet hire is available).
Thank you
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
