Series 2 rs (rwd) SILVER
Wrecking
All parts available. Car is undamaged and registerable.
If not listed ask. If a price is no good let me know, I'm negotiable and reasonable person. I want to sell the stuff, butnot give it away!
RB25 Neo bottom end, 140,000ks excelllent condition $500
Rb25 neo head, modiifed for external vct feed for 2530 use. including oil line and tee piece, standard cams and covers, no vct pulley or cas $600
vct pulley with mod to allow adjustment and diallling in of cams $100
Alternator $75
Starter motor $75
AFM, worked great $60
Neo CAS $200
stock air box and snorkel $60 suit R34 also
idler and tensioner, less than 6000k's use $50
HKS return flow type r cooler kit. Flowed just over 300rwkw no worries. Has been dented into something, doesnt leak or affect performance. This is a full size core, with no cutting required at all. Including all clamps and joineres etc. Been painted black. Can spin around and not see dented bit so all good! $250 Also fit R34 GTT
Very nice sounding custom 3 inch dump back exhaust. Below legal noise, no drone!!!!! Hoooker aerochamber muffler and berklee straight through rear, flowed over 300rwkw no worries, fits nicely. 1/2 of it is stainless, all mandrel bent $400
Standard exhaust manifold $50
rb26 oil pump $80 great for rb2530 build
R33 standard turbo, great condittion $180
Fan with clutch,no cracks, worked well $55
Alluminium radiator , pretty thick , stock shroud fits on it. kept car temperature controlled perfect, $100
Air con compressor $75
Power steering pump $75
Series 2 tail lights, complete, perfect condition $250
Headlights $250
Grill, dodgy black paintjob, $50
High beam lights, (spotlights in the grill ) $150
Standard RS front rotors, good condition,no shudder etc. $75
Front calipers with pads clips etc $50
rear rotors $75
Rear calipers $55
RE4R01B standard valve body $75
Instrument cluster (dash) auto, just over 100,000 ks $125
Power window switch $75
climate control unit $65
Steerig wheel and airbag, good nic, $75
Clear side indicators, fit a bit loose but never fell out! $25
Tailgate $100
RS4S alloy wheels, rear tyres 1000k's use, Maxxis tyres, front more use but still heaps left , wheels in good condition, few small marks $400
HEAPS more, cant remember, ask me for a price or make an offer.
PICS Available, cant be bothered uploading heaps of pics for no reason, ask me if you need a pic.
Cheers
Ben
I'm after the passenger side sunshade if it's the same as an R34....Could you possibly post a pic? how does $15 plus post sound?
No worries. Not sure if the same or not.
Edited by Ben C34
Ok. Some of the prices I listed are a bit off the mark, so hit me with a sensible offer for what you need.
A lot already sold, will update what's left soon.
Cheers
thanks ben, but yeah it's a bit different. The mounting point is a different shape, so the bolt holes may be different. I'll try and find an r34 one.
cheers.
  • Like 1
You did an LS1 coil on head plug setup for your Stag, didn't you? If so, are you selling it?
Yes I did, and at this stage another guy is interested in a pack including nistune, z32, coils, sway bar, r34gtt brakes etc...
I will let you know if he doesn't come through with the cash.
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
