Hi guys up for sale is
Kkr front mount black series intercooler to suit r33 and r34 Gtst and gtt
I have also installed a brass nipple that goes on the over pipe so no need to worry about that
Has some marks and scratches but it works perfectly fine and is ideal for those who want to remain hidden in the shadows
Some bends in pins here and there.
Want $150 firm
Also up for sale is a pair of Xenon headlights to suit r34. Comes with aftermarket ballast and bulbs. Blue/white post-101240-14203526484542_thumb.jpgpost-101240-1420352681057_thumb.jpg
One bracket is broken. Still secure when fitted.
Make me offers on the lights
If you want me to post please organise it from your end of possible.
Cheers boys
0411538933 text me
Pickup from Toongabbie NSW
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
