Gday all,
Asked a similar question in Dec 2002 but there has been additions to our knowledgebase since then.
My R33 has paint code DN0. Variously known as Ice Green, Aqua Blue or Green Metallic depending on who you ask/what you read.
I have recently obtained the FAST software and delved into some of its files. This is where I found the "Green Metallic" mentioned above.
I am only aware of a few R33's in this colour. Sooooooooo, my questions are:
Does anybody know how many R33s were made in this colour ?
Would this info be available easily through FAST ?
If not, would I be able to query the database for these fields ?
Is there someone close to the source who could find out for me ?
Do I have to spend the next 30 years going through each VIN to find out ?
I think that's about it. Any advice/discussion welcome.
El Bee
https://www.sau.com.au/forums/topic/45237-colour-code-build-numbers-etc/
Thanks Duncan,
I am sure that if the correct databases are found, we could work out a query for this.
Not too many would be interested in my case, but there may be other situations where a good query would be helpfull. How many blues were made etc ?
Just think that it would be nice to know, especially if I were going to sell for a GTR or something.
Enjoy.
El Bee
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
