Actually i remove all calipers and clean them thoroughly, paint them before going back on, cut off stone guards if tracking it, braided lines, brake cooling ducting, decent pads research that, decent slotted rotors research that, keep shims or get new project mu shims some pads have rubber backing or sticking backing, research that, get some copper grease, research that... See i can get carried away
Something I have never heard anyone else say, but I have found purely from personal experience is worn wheel bearings (even the tiniest play) can cause brake squeal because it allows the rotor to move imperfectly in relation to the brake pads. This causes uneven wear and after a while a squeel. If someone is out of options its worth changing your wheel bearings, machining your rotors, installing new pads and seeing if the noise goes away.
Edited by sonicz
Usually worn bearings lead to brake shudder and disc thickness variation.
The disc moves around between the pads leading to uneven wear moreso than brake noise.
Ive seen cars with seriously worn bearing never make a sound, the only hint was bearing noise and then brake shudder.
took the r33 to another mechanic (works on alot of performance cars) it was apparently the rear pads, they swapped over the Bendix pads with Repco thermoquite ones & the squeak did go away.
now a week after it squeals again ..
imsomadritenow f**k
wat to do?
really considering selling the car after getting the brakes done by mechanics twice and 10 times myself just for it to squeak again
The answer to the problem is written time and time again throughout this forum and many others, and also sarlier in this thread...
So your experiencing people that dont know brakes, dont give up.
Its not your pads, its not your rotors, its a high frequency vibration, go get some copper grease,
one thing i know is that its definitely not a copper grease issue iv used a kilo of anti squeal behind the pads aswell as applying copper grease without no effect
what do these marks mean?
http://i.imgur.com/kKX9wcv.jpg
http://i.imgur.com/8V7yyrX.jpg
iv only had these pads for less than 10 days now
I think you need to rough them up and then go bed your brakes in. And be mean about it.
Kind of looking like they are glazing.
I have no shims or copper grease and just put in a set of intima sr pads and have no squeel.
thats the thing, even if that did get rid of the squeaking a week later it wil just rise again
i need to know the root cause of this
Squeal is vibration so if roughing them up doesnt allow them to stop the surfaces jumping around on eachother then you need some baffling to take up the vibration. Chamfer the leading edge of pad, if it still squeals then your shim rubber is very good
Post 3 pictures.
1 of your assembled caliper looking into it so we can see how the pad assembly sits.
2 of all the shims, clips and pins being run taken off the pads and the back of the pads.
And 3 of the pistons faces in the caliper and the leading/brakeing edge where the pads put thier force into the calipers.
Those pictures you showed of the pads show they were not bedded in yet, some pads make noise till they bed in.
  • 1 month later...
Pad compound has a lot to do with squeal as it generated movement at a high frequency.
I cured many by making alloy slugs that fit into the piston and are about 1 mm thicker than the original shim, machined them down so they hold the pad dead flat and true on the rotor with no movement thus no squeal.
Remember you do not necessarily need to bed brakes these days ( Depends on the Pad ) and in some cases if you do you will over heat the compound resulting in hardening of the pad and reduced grip and more vibration thus squeal.
2 or more spots of Silastic applied to the back of the pad and pressed into place before it sets after allowing it to set this provides a tiny shock absorbing layer :) in a similar fashion to the PBR Squeal Stop solution.
Those pads in the pic look normal, those scuff marks that run diagonally don't. Is that from roughing them up last time?
Have you had the calipers inspected for sticking pistons and have you checked the spring plates don't allow the pads to move up and down in the caliper.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
