  • Replies 345
Calling Tuggeranong Nappy Valley started WAY back in the late 70s early 80s when all the young couples moved out that way and built homes and hatched babies... It was hugely cheaper to to buy / build out that way compared to living in 'inner' Canberra. Plus for years it was the only place where you could actually buy land and build somewhere new......(Gungahlin was still sheep paddocks)
Queanbeyan used to be called 'Struggle City' (still is by some) as for years you only really lived out there if you were deathly poor. Homes, units, flats purchase and rentals etc were all CHEAP compared to Canberra.
:elaugh:
its now called struggle town not struggle city thats about the only change that i know of :D
Hey all,
I haven't got a skyline, but my little dato ute is powered by a Nissan CA18DET.
It is candy apple red and has a Plazmaman FMIC, Garrett GT28 turbo, BOV, FR17" Simmons, Stinger 4424 EMS, borg warner 3.9 diff.
I've been poking around this site for quite a while now and there seems to be some pretty good info.
See you all around!
  • 1 month later...
Hi all,
Ive been a member for a lil bit but havent really said to much,
First time to say anything here...
I Own an R32 Skyline, its Blue with a purple pearl. Stock rims, Body kit...
You might of seen me around, prob tried to take one of yas on...
Umm do you guys organise any cruises, coz im sure it would be fun if we all got together and went for a cruise...
Well just letting you know im here
And see yas out there.
Hi I have posted once or twise (see above) but never introduced myself. I live in the "Nappy Vally" and drive a R33 GTS-T in gun metal with a veilside front bar and crome 19's.
Anyway me and banger (posting above) have started a new canberra car club thingy at www.alwayssideways.com . We put the site up 2 weeks ago which includes a forum, pics and vids and some other random sh*t. Anyway check the site out if you have some spare time and want to have a chat or check out some vids... Your contrabution will be appreiated...
Thanks & see you around.
HI, i'm new to this forum, and also to be a skyline owner within the next few days. Just thought id say hello and find out what else goes on on this side on the line, i've been a bit of a toyota nut lately, gone through m,any fazes of cars. had rotors, cordias, the sprinter i currently own and am now adding an R32 gts-t to the list.
  • 4 weeks later...
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
