I have had a slight 'miss' for quite some time, only at idle and very random... have narrowed it down to coil packs or O2 sensor.
on sunday i decided it was time for a plug change and at the same time i thought could check the resistance of my coil packs to see their state of health. and see if it could be the culprit of my miss.
went down to supercheap and bought 6 plugs (NGK: BCPR6ES - 0.8mm gap) that are the exact same ones as were already in the car.
so... only took about 1 hour - took off the intake pipe that runs over the cam covers, took off the required hoses, loostened the required clamps etc.
came to the plugs... took off one coil pack at a time, checked the resistances (all ended up being the same), chagned the plugs. upon inspection the plugs were absolutely great and didn't even need a change (that's copper plugs in for 10,000kms and counting)
Put it all back together... turned the key... NOTHING!
aaaaaaaaaaaaaaaarrrrrrrrrrrrrggggggggggghhhhhhhhhhhhh!!!
it cranked but wouldn't ignite!
checked all hoses for a massive leak - nothing
checked all the coil plugs - everything plugged in and ok
by now dad was pissed at me for "playing with your bloody car again" (hehe) but i was determined i hadn't stuffed anything. he thought that i had blown the ptu or something.
so, after a day of trying to diagnose the problem i thought stuff it, i'll just put the old plugs back in, after all they were the only thing that i had changed.
presto, car started first time!
wtf??!?!?!
what's the liklihood of getting 6 stuffed plugs? or is one completely stuffed plug good enough to not let the car even start and idle like crap?
I'm going to try and get a refund at supercheap but i can't lie as the tips of the plugs don't look new even with a clean since being exposed to fuel and the inside of my cylinders - might have to tell them the truth and risk not getting a refund.
well thought i'd share my odd and annoying experience and get some sympathy for wasting a day that i could have otherwise spent on the forum / with the missus / anywhere else really!
at least i can say that i have determined that it is most likely my O2 sensor that is causing my miss at idle.
anyone else have any odd experiences with their engine?
have good ones,
Warren.
https://www.sau.com.au/forums/topic/45408-spark-plug-scare/
Just because they were the ones that were in there, doesn't mean they're the right ones.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=32825
https://www.sau.com.au/forums/topic/45408-spark-plug-scare/#findComment-924819
that link is to NA engines not turbo engines (i have an rb20det)
also, i know they are the right ones as when i bought the car it had crappy old plugs that needed a change badly and i put in the BCPR6ES with great success then...
https://www.sau.com.au/forums/topic/45408-spark-plug-scare/#findComment-925952
OK..... go have a look at what NGK has to say on the matter.
http://www.ngk.com.au/
1991.8 - 1993.8 NISSAN SKYLINE 2000 TURBO RB20DET
Spark Plug
Part No.
Recommended Plug
PFR6A-11
Iridium Option
BCPR6EIX-11
1989.5 - 1991.8 NISSAN SKYLINE 2000 TURBO RB20DET
Spark Plug
Part No.
Recommended Plug
PFR5A-11
Iridium Option
BCPR5EIX-11
https://www.sau.com.au/forums/topic/45408-spark-plug-scare/#findComment-926239
Spark Plug
Part No.
Recommended Plug
PFR6A-11
Iridium Option
BCPR6EIX-11
Spark Plug
Part No.
Recommended Plug
PFR5A-11
Iridium Option
BCPR5EIX-11
isn't BCPR6ES-11 the exact same plug as the PFR6A-11 except copper instead of platinum...?
i think so... i chose the copper option for my own reasons
https://www.sau.com.au/forums/topic/45408-spark-plug-scare/#findComment-929026
bcpr6es with 0.8mm gap are good plugs for skylines, and even the bcpr7es if you want to go for the extra heat range - the 7's seem to respond well to boost. If you are getting an idling problem definately have a look at the o2 sensor, they are $99 to replace so pretty cheap. If you take out your o2 sensor and its got a nissan emblem on it definately change it because its probably the original one and they are only good for about 40thou kms. Other thing you can try is cleaning the afm with carby cleaner and cleaning the AAC. My skyline developed a spluttering rough idle and i was told it was a vacuum leak. I took off and cleaned every pipe and refitted all the hose clamps as tight as possible without wrecking the hose clamps ( sorry i actually wrecked about 2 hose clamps....its hard to know when to back off when tightening up those bastards! )replaced the o2 sensor, cleaned AFM, reset ECU, changed plugs and cleaned AAC and now it is fine and running a hell of a lot better. The good thing is that you can check this stuff yourself and do all this stuff in an afternoon.
https://www.sau.com.au/forums/topic/45408-spark-plug-scare/#findComment-930994
well as this has been a long-standing problem i have tried lots of stuff (most probably irrelevant to the problem, but hey i tried, right?):
- cleaning AAC valve
- cleaning AFM
- adjusting TPS
- re-grounding fuel pump
- cleaning carbon off the O2 sensor
- changing fuel filter
- reset ECU
- checked coil packs (although 'Roy' suggested this is better done when they are warm)
and for the record, the O2 sensor was an NGK one with the part number "0A08" on it...
Waz.
https://www.sau.com.au/forums/topic/45408-spark-plug-scare/#findComment-931070
no i dont. i have ordered the data cable that plugs into the consult port and to a laptop so you can check error codes and stuff. i may get it this week. if i do ill bring it down with a laptop sure but dont like chances of getting the cable this week
https://www.sau.com.au/forums/topic/45408-spark-plug-scare/#findComment-931575
I have just recieved an email, my consult cable is on the way, express post from adelaide. I should have it by Thursday tops. Will bring it down on the weekend to dyno day if anyone would like a health check up
Assuming it all works fine of course :D
https://www.sau.com.au/forums/topic/45408-spark-plug-scare/#findComment-932687
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
