Check your CAS mate, mine was busted with very similar symptoms: http://www.sau.com.au/forums/topic/326043-resolved-misfire-in-r34-gtt-rb25det-neo/
Edited by V28VX37
It started happening lastnight it did it twice and then when i drove it this morning it was happening slightly again but after driving for 10 minutes it started completely dying its normally around take off, at one point i was at the lights and i reves the engine up slowly and when it hit around 2.2k revs it started to shutter then when i took of from the lights slowly 5 metres up it started shuttering bad its feels like when you tap the accelerator hard, i had to pull over because the accelarator was keeping it at 1.5-2k revs and not going any higher i turned the car on and off tryed reving it a few more times it finally worked got 15 metres around the corner it started jerking and doing the same thing and the engine light came on i pulled over turned it off tryed to look for a problem turned it back on and it reved up fine and i made it home from there which is a 5 minute drive but it was slugging and shuttering most the way
Just my two cents but I had a afm issue not long ago and ended up having to replace it, it's a very fragile part and even by cleaning it they can be damaged. If it is your afm I suggest replacing it with one that definitely works 100%. A slight bump can kill them so be careful
it was doin it a bit the night before and i cleaned the afm the next day before i went on the short drive, 10 minutes later it was still bad then just got alot worse,ill look into getting a new afm see if that helps at all, i saw similar problems last night where it was coil packs, could it be my coil packs aswell ? Thanks for the help guys i really apreciate it
Just a quick update guys went to start car this morning kept wanting to die and would not at all go past 2k revs i pop the bonnet try bush the afm cord in and it dies, so i took the cord out and put it back into the connection now she will rev normal, so definately has to be afm
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
