hi guys
im sure this has been covered countless times, but i got some funny reading and im just after a second opinion
Compression test values are as follows:
DRY TEST (no oil):
1 - 110 psi
2 - 105 psi
3 - 105 psi
4 - 100 psi
5 - 115 psi
6 - 100 psi
WET TEST (oil dropped in cylinder) :
1 - 120 psi
2 - 125 psi
3 - 105 psi
4 - 195 psi
5 - 150 psi
6 - 160 psi
the wet test threw me off about with how much variance there was, but as well as that it seemed quite low on the dry test
thanks in advance
cheers
ohh i forgot to mention its my mates r33 im looking to buy
just wanted to do a check before i commit....as far as i know it runs pretty sweet
Edited by stagea_1998
Why did you test it? Any problems?
If not just drive it. People get caught up and just confuse themselves with comp tests.
if it runs well and doesn't blow smoke, don't worry about it.
btw does it have standard cams? the number are low but cams can affect that (and also the exact testing procedure of course(
nah all standard internally theres just a few basic bolt ons
im pretty well inclined to say its fine but i always like to have a second opinion when im unsure
Re The testing procedure - figures do not seem consistent (bad or good) - Dry V Wet variances. Readings on some are all over the place.
I'd have some one else who does this often re-test first. It's just too inconsistent.
Eg. cyl 4 has jumped 95psi
Variances
10
20
0
95
35
60
thats what i thought ...its a massive jump!!
i did use a second tester to check as well after i saw that to confirm the reading and sure enough it was dead on
ive done plenty of comp tests over the years on cars me and my brothers have bought and with the same test procedure id get pretty consistent readings...so id say ive an idea what im doing lol
this ones thrown me though....
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
